Username Post: Oil press. Gauge fitting into intake        (Topic#361904)
Adam63impala
Adam63impala
Loc: From Memphis to Florida
Reg: 12-01-15
07-26-20 05:54 AM - Post#2799564
Going to install my oil pressure gauge. What size NPT is the fitting that screws into the intake? Thanks as always guys/ gals
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
07-26-20 08:01 AM - Post#2799580
    In response to Adam63impala
Um, I'm not aware of any oil pressure gauge that screws into the intake manifold?
Do you have a picture of where you plan on installing this gauge?
Steve
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
07-26-20 08:45 AM - Post#2799585
    In response to steve65
It is kinda hard to see back there, so it is understandable that you might have thought it threads into the intake. But the oil pressure sender actually goes into the engine block, not the intake manifold.
- Dave
1964 Impala 4-door sedan
junky
Loc: Northeast CT
Reg: 06-27-10
07-26-20 09:14 AM - Post#2799588
1/8" NPT = National Pipe Thread. What ever you decide to do, make sure to use only pipe dope, and not anything that contains Teflon. I have seen people crack things when using Teflon since the Teflon reduces any indication as to when something is tight enough. In short, it reduces friction, so you have no idea of how tight it really is. Pipe threads are tapered threads, so all you need is some pipe dope to seal it from leaking. Also, don't use brass fittings, because they might crack from the vibrations, since brass is softer. I speak from experience more than 50 years ago.
Execution time: 0.242 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:54 AM
