Username Post: 1940 master deluxe 216 l6 water pump interchangeable        (Topic#361861)
Robbie esplana
Reg: 07-22-20
07-23-20 03:54 AM - Post#2799291
Im overheat and cant find a water pump any where — i have a 1940 master deluxe and have searched hi and low for a water pump and no luck —- ive heard some of the 235 water pumps will fit as some say no and some say yes —- if it is what year 235 and what part number — because i cant find a waterpump is why im thinking of doing a engine swap to a 235 —— but my 216 runs perfect aside the over heating
2blu52
Deceased Member RIP
2blu52
Reg: 03-12-02
07-23-20 05:18 AM - Post#2799293
    In response to Robbie esplana
What have you done to isolate the water pump as the root cause of the over heating. There is nothing there to fail other than a bearing or possibly a seal. Go to the manual and follow the guide lines to determine the cause of heating. When I had a pump failure I just went to a small local parts house and they had the water pump on the shelf.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
07-23-20 06:55 AM - Post#2799301
    In response to 2blu52
But Blu that was in 1946.
07-23-20 09:06 AM - Post#2799311
Welcome to ChevyTalk
Have you tried -- http://www.chevsofthe40s.com/
The Filling Station http://www.fillingstation.com/
Kanter http://www.kanter.com/
Landon’s Stovebolt http://www.stoveboltengineco.com/
http://www.steelerubber.com/
http://www.thehotrodcompany.com/
Jim Carter http://www.oldchevytrucks.com/
Your local Napa Store
29-41, 42-48, 49-54 Moderator
2blu52
Deceased Member RIP
2blu52
Reg: 03-12-02
07-24-20 05:18 AM - Post#2799389
True and again in 2004!
THOMAS JEFFERSON
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-24-20 07:07 AM - Post#2799407
Rebuilds available at NAPA.
https://www.napaonline.com/en/search?q=Nty%3D1%2 6N...
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
07-24-20 07:50 AM - Post#2799413
    In response to 1971BB427
It has been a few years ago but I bought a water pump for my 41 Chev 216 ci motor from Advance Auto Parts . I don't remember what I paid but it was a
not over $50 or $60. Is it leaking coolant or making noise? It might be gasket failure or perhaps it has worked its way loose. Check Advance online for a pump. You might have to tell them its a 1942......Phil
The only guarantee I can give you is I can"t give you any guarantees
Markk
Loc: Lothian, Md.
Reg: 06-14-06
07-31-20 09:46 AM - Post#2799993
    In response to 41wildthing
According to the Master Parts book, 39 and 40 are the same water pump assembly. Interesting that the repair kits are the same for 37-53 but the gaskets are different after 40. Looks like a difference may be in housing after 40 but not in the impeller??
Execution time: 0.099 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:00 AM
