Username Post: BBC Oil Pan to Frame Clearance 68 Camaro        (Topic#361836)
68Cam
Loc: Des Moines, IA
Reg: 05-29-04
07-21-20 09:40 AM - Post#2799162
Since 68 Camaros came with 396s in them, I wouldn't think there would be an oil pan to frame clearance issue - as long as the BBC frame-side mount stands are used. A friend says he has put BBCs in several & every time there is a clearance problem - he has modified a large area (notched) in the frame for the pan to fit. I want to install a 502 on a stock frame. Is there any problem with the newer generations of BBCs fitting on a stock frame? Are there certain oil pans that are better than others etc. ? Thanks
pdq67
Loc: Columbia, MO, USA
Reg: 08-31-02
07-23-20 09:12 PM - Post#2799367
    In response to 68Cam
FWIW,
I have a 496 in my '67 Camaro now.
It fit fine.
NOS BBC frame stands and the red poli motor mounts. I just kicked it over to the pass. side at the tranny mount and used one hole to tie it down.
pdq67
Edited by pdq67 on 07-23-20 09:13 PM. Reason for edit: No reason given.
68Cam
Loc: Des Moines, IA
Reg: 05-29-04
07-25-20 08:45 AM - Post#2799494
    In response to pdq67
Thanks for your reply. I'm not sure what you are describing that you did with the trans mount? Also, I'm assuming your block started as a 454. I'm wondering about after-market blocks - Dart etc. Maybe there's no diff, just wondering? As far as the pan to cross member clearance. Thanks
pdq67
Reg: 08-31-02
07-27-20 10:35 AM - Post#2799669
My 496 engine started life as a 454 early '70's P/U truck engine so I have a P/U truck oil pan on it with no problems that I can tell.
I would rather have a 4 or 5 qt 396 pan on it but whatever.
I say this because if I remember right? I put 7 qt's of oil in it..
pdq67
68Cam
Loc: Des Moines, IA
Reg: 05-29-04
08-01-20 12:48 PM - Post#2800085
Thanks again for your reply & info.
Execution time: 0.152 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:34 PM
