Username Post: LS1 fan blade size?        (Topic#361804)
07-16-20 08:31 PM - Post#2798922
What size are LS1 fan motor blades? My ZZ4 is running a little warm but it’s above 100 degrees now. The 454 radiator cools quickly with minor speed. At idle, temps with a/c rise a little too high. Temp range is 210-225 at lights. I’m considering upgrading the fans. Or adding an auxiliary fan for a/c cooling.
'08 GMC Acadia 3.6L SLE
TAT_2
Member #26 "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
07-25-20 03:59 AM - Post#2799473
1995-C10 HAS 1 & POSSIBLY A RULER !!!
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6SPD/RAG TOP
NEXT ?
07-25-20 05:21 AM - Post#2799480
    In response to TAT_2
100+ outside.
I've realized if I need info usually it's not on Google or internet. Modifications require ingenuity.
1965C-10
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
07-25-20 12:38 PM - Post#2799519
I just looked on Rockauto for 1999 Corvette radiator fan, says the fan diameter is 12.999 inches, might as well say 13 inches, on this car it has 2 fans.
I understand they both run together on high or low.
On low the ECM cuts voltage in half for lower speed.
You can buy the whole fan assembly with shroud, both motors and fan blades there for $112.79 plus tax and shipping, says lifetime warranty.
Not sure if it would fit your radiator, thought of taking my fan assembly off and see if it would fit the 1965 C10 radiator, then order this, however would need wiring harness or make one.
07-26-20 06:35 AM - Post#2799568
    In response to 1965C-10
1965-C10,
BADBOW is running a set of LS1 fans. I've been running them for years. I had a good original OEM set. OEM worked better over aftermarket replacements. The OEM set seemed to pull more air. They sure were louder when on. I know temps probably went up a bit since I closed the radiator and condenser gap. The A/C works better with a closed gap. I'm asking about the fan blade size for another modification. I'm thinking about installing Spal 13" fans on a stock LS1 fan housing. The shroud fits perfect between the 454 radiator end caps.
If you want to run two speeds, use a Volvo relay harness. I run mine at full speed. Either with an A/C trinary switch or engine head temp probe trigger.
Edited by gchemist on 07-26-20 06:38 AM. Reason for edit: No reason given.
07-26-20 06:40 AM - Post#2799569
You can find a pic of aftermarket fans bolted on here.
Edited by gchemist on 07-26-20 06:40 AM. Reason for edit: No reason given.
Execution time: 3.174 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:30 PM
