Username Post: ‘66 c10 Muncie gearshift        (Topic#361763)
Mskoch
Reg: 07-13-20
07-13-20 01:49 PM - Post#2798607
New to the site. Starting my 66 shortbed fleet side restoration. I have a Muncie 4 spd lined up to replace the 3 on the tree.... anyone have a recommended gearshift to bolt on that is high enough without having to reach to shift? Thanks in advance!
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
07-14-20 10:43 PM - Post#2798770
    In response to Mskoch
Look up HURST shifters,see what they have
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
64K10
64K10
Loc: Cali
Reg: 06-25-04
07-17-20 05:11 PM - Post#2798968
    In response to Lead sled
^^^^ Yes, Hurst is going to be your best bet.
As for "stick" length you may have to get a piece of bar stock (cut to desired length, drill four holes and bolt it to the shifter / stick).
Look here: https://www.shifterdoc.com/Hurst_Replacement_Shi ft...
Stick #5384331 is probably the tallest at around 16.5".
64K10
Edited by 64K10 on 07-17-20 05:17 PM. Reason for edit: No reason given.
Execution time: 0.273 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:45 PM
