Username Post: Rotor races/bearings        (Topic#361756)
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
07-13-20 08:31 AM - Post#2798582
Recently bought a pair of rotors AC Delco Detroit
along with a Timken Bearing/Race Sets. Confused on which way to go..remove the AC Delco races and use the Timken sets? Or use the AC Delco races? - if I can even get the AC Delco races out! \
Thanks.
Stan
It's all good. mostly
Edited by 4dr 57 on 07-13-20 08:32 AM. Reason for edit: No reason given.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
07-13-20 08:37 AM - Post#2798583
    In response to 4dr 57
I would use the races that go along with whichever bearings you use.
4dr 57
Reg: 11-10-04
07-13-20 08:45 AM - Post#2798584
    In response to 5Larry7
ok. that's what I will do as well. Thanks Larry!
I did notice a little smoother action right away with the Timken race when I put the bearing in both races. Timken are labeled USA
AC Delco races read PEER CHINA
Edited by 4dr 57 on 07-13-20 09:31 AM. Reason for edit: after change findings
07-13-20 09:49 AM - Post#2798594
There is normally notches in the rotor hub that allow access to the back edge of the race. You can use a large punch or drift to knock the race out.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
07-13-20 03:59 PM - Post#2798625
Thanks.
Stan
You replace bearings and races as a set.
4dr 57
Reg: 11-10-04
07-14-20 11:15 AM - Post#2798704
    In response to acardon
thanks acardon there was ah notch in the hub Used a hard softer punch that needed a little refurbishment along the way, and a 2.5# sledge to get them out. I didn't care for the rough interior of the holes but I guess that's how its done, idk. AC Del. Pro. rotors too! Makes me wish I'd bought Centric Pro. as they are very round products. All done now. Was going to put the front back together but had a water leak in the shed that needed attention first.Isn't that just the way of it!
Thanks Again.
Stan
Execution time: 0.139 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:03 PM
