Username Post: rear end        (Topic#361673)
olbud
Reg: 07-06-20
07-06-20 12:04 PM - Post#2798050
I have a 69 c10 rear end with RA0303w2 and need a pinion yoke for it .the 1 that was it is nolonger around and I see theres like 15 different 1s. all I know its 29 spline . any help would be great The ratio is 7.03 thanks much
64K10
64K10
Loc: Cali
Reg: 06-25-04
07-17-20 06:34 PM - Post#2798971
    In response to olbud
Ok, lets start over...
Where are you picking up the "RA0303w2" string?
Off the axle tube or the cast iron diff center section, or?
Do you have 6 or 8 lug wheels?
What is the bolt count on the diff cover: 10 or 12?
Most common is the GM 6 lug, 12bolt truck diff.
The 10 bolt might be a Dana 44.
Both these are 30 have spline pinions.
The Dana 60 has a 29 spline count (10 bolt diff cover), but think these may have been on 3/4T trucks.
64K10
Execution time: 0.124 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:21 AM
