Username Post: HEI Distributor        (Topic#361581)
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
06-30-20 07:14 PM - Post#2797587
I finally bought an HEI distributor and plan to replace the stock dist. Am I correct in assuming that I can eliminate the ballast resistor completely? Thanks for the help.......Phil
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
06-30-20 08:09 PM - Post#2797593
    In response to 41wildthing
V-8,66 cyl, 6V,12V?
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
07-01-20 03:43 AM - Post#2797602
    In response to 2blu52
1941 Chev with 216 cubiv inch motor 12 volts.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-01-20 06:46 AM - Post#2797611
On a factory Chevy HEI it wont need an HEI, but you didn't mention what brand you have? I converted my V8 to an Accel electronic and it clearly states in the instructions to use the ballast resistor, so I had to on mine.
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1937 Austin gasser 327/TH350
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
07-01-20 09:15 AM - Post#2797639
    In response to 1971BB427
It is an after market unit. Probably Chinese.
I bought it from Amazon and it came from a company
called A-Team Performance. I think they hail from
Arizona.
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
07-01-20 12:18 PM - Post#2797649
Did it come with instructions ? If not I'd give them a call or a e-mail and ask.
2blu52
2blu52
Reg: 03-12-02
07-01-20 03:35 PM - Post#2797667
I used Pertronix, stock wiring, no resistor needed. Still on the car and new owners have it installed on a 54, 235 Pickup engine which replaced my 216. I had no problems with it and did not miss setting points and replacing them at all. With 12V you will need a resistor and a coil with built in resistor would do the trick.
THOMAS JEFFERSON
Edited by 2blu52 on 07-01-20 03:36 PM. Reason for edit: No reason given.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-01-20 04:38 PM - Post#2797669
Arizona.
If it's one of those that looks like an Accel, then they'll tell you to use the Accel instructions, which say to use the resistor. Contact the seller, and they should have instructions, or direct you to a site.
I ran into this with an Amazon points conversion kit I did for a friend, and that's what they told me to do.
PS-They have a Facebook page I found, so you can contact them and ask for instructions.
https://www.facebook.com/ATeamPerformanceParts /
Edited by 1971BB427 on 07-01-20 04:45 PM. Reason for edit: No reason given.
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
07-02-20 04:02 AM - Post#2797693
Thanks guys for the help. I will let you know how it all turns out....Phil
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
07-02-20 10:54 AM - Post#2797727
I have one of those. Hook a wire to it from the switch, and drive it.
52 Styleline Fourdoor 62 235 PG
IgnitionMan
Reg: 04-15-05
07-02-20 02:20 PM - Post#2797740
Large coil in cap HEI, 12 volts, MUST be negative ground system, no resistor needed.
SPARK PLUG GAP NO LARGER THAN .045.
A PerTronix drop-in points replacement IS NOT AN HEI. PerTronix does sell a Chinese knock off coil in cap large HEI also, that IS an HEI.
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
07-05-20 08:43 AM - Post#2797960
    In response to IgnitionMan
I don't think the unit I have is Pertronix unless
it is made by them, but I have no idea. Appreciate
the help.....Phil
IgnitionMan
Reg: 04-15-05
07-05-20 08:50 AM - Post#2797961
There is a white sticker on the ignition unit inside the distributor, but I can't read it from the picture. What might it say on the sticker???
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-06-20 07:17 AM - Post#2798036
the help.....Phil
Maybe post a picture of your unit, and it might help identifying it?
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
07-06-20 09:20 AM - Post#2798041
I will post a link, but if you google
www.ateamperformance.com one of the urls I think it says in the description distributor for early 6 cyl
Chevy and up to 60 something. That is the one I have.....Phil
IgnitionMan
Reg: 04-15-05
07-06-20 03:11 PM - Post#2798061
I finally got the website linked to open.
Chinese, same factory that made the old Pro-Comp stuff that was dubious.
Yes, full battery voltage, NO ballast resistor or resistor wire, negative ground only.
Plug gaps .045 MAXIMUM, no variation.
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
07-08-20 05:41 AM - Post#2798200
Thank you Ignition Man for the guidance. I figured it was made in China. I just hope it works properly. I guess time will tell....Phil
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-08-20 08:58 AM - Post#2798214
Hope you have good luck with that distributor. Pro Comp was very sketchy, and I've not heard anything on these labeled under newer names.
I had a buddy who bought a Pro Comp distributor for his 350 SBC in a '56 Chevy, and two weeks after he installed it the car coughed to a halt. We were headed to a car show, so I helped diagnose it. I tested power to it, and it was fine. I pulled the cap and told him to crank the engine over, and the rotor kind of wiggled, but didn't turn! It had sheared the shaft inside the distributor, and he had to tow it home. He bought a replacement distributor of another brand and got it going again. I don't think he even tried to get his money back on the bad one?
Execution time: 0.281 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:29 PM
