Username Post: Bypassing resistor wire        (Topic#361571)
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
06-30-20 07:05 AM - Post#2797518
I'm doing a Pertronix Ignitor conversion on a 1967 Pontiac LeMans. I need to bypass the resistor wire from the firewall bulkhead connector to the coil + terminal in order to have a full 12 volts at the coil.
I've looked at the fuseblock and the only spare terminals are always hot. Unlike my 1965 Chevy (which I converted to HEI) there's no SW BATT terminal that's only hot when the car is running. So my alternate plan is to trace the resistor wire to the bulkhead connector and replace it with a conventional wire.
I could cut the wire say 1" out from the connector and splice in the new wire or pull the terminal out of the connector and attempt to pry it open and solder in the new wire. Neither option is really appealing to me. I was hoping to be able to leave the resistor wire in place, coil it up and tape over the connector then run the new wire to a different location. I'm trying to make this as clean and reliable of an installation as possible. Before I proceed does anyone have any suggestions?
Thanks,
Johnny
1965 Impala SS
505/4-speed/3.90
06-30-20 07:58 PM - Post#2797592
    In response to Johnny468
On my
1957 Cameo Carrier
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
07-01-20 03:51 PM - Post#2797668
https://www.walmart.com/ip/FUSE-CIRCUIT-TAP/1 52924...
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
07-10-20 06:30 AM - Post#2798340
    In response to TAT_2
Just a quick follow up, I did go with a fuse tap and everything looks like it working great. I used the wiper circuit since it's 20 amps, the tap fit nicely around the fuse and the fuse snapped tight into the fuse holder.
Pertronix Ignitor and coil made a big difference, car runs much better now, feels like it pulls harder and hot starts are definitely improved.
Johnny
1965 Impala SS
505/4-speed/3.90
TAT_2
TAT_2
Reg: 10-29-00
07-10-20 03:48 PM - Post#2798367
TIED MY HOLLY ELECTRIC CHOKE INTO THE WIPER CIRCUIT.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Execution time: 0.09 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:32 PM
