Username Post: Speedo jumping        (Topic#361568)
67 Al
Reg: 06-26-18
06-29-20 07:01 PM - Post#2797490
Speedo jumping around so tried to pull cable out from tranny to lube. Wont let go from the head in car. Dont want to brake something. Any tips to get it loose? On 55 chevy car. Thanks
06-30-20 04:58 AM - Post#2797510
    In response to 67 Al
I'm pretty sure it has to come out from the speedometer end.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
06-30-20 06:51 AM - Post#2797523
    In response to acardon
What Don said.
Russ
Russ
Loc: Sacramento, CA USA
Reg: 12-16-99
07-10-20 08:02 AM - Post#2798349
Will the speedometer head come out of the dash relatively easy? If so, once the speedo cable is detached from the transmission, why not remove the speedo unit and attached cable out of the car? Then you could work on it from the bench.
Execution time: 0.393 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:25 AM
