Username Post: fuel pump cycle control module        (Topic#361566)
tractordrivindan
tractordrivindan
Loc: Riverside county ,CA
Reg: 04-05-19
06-29-20 07:37 PM - Post#2797486
i have a 1991 R2500 suburban, the repair manual does not break the circuit board down. there is a part on this board that has a heat sink attached to it,unfortunate foe me this (what ever it is) is overheating and breaking open and spilling its guts. at some point after running the engine it shuts the fuel pump off. after sitting overnight when things cool down the fuel pump is allowed to run (for what ever time).if the circuit board is pulled the pump is allowed to run as normal (so far with not a lot of time driving). I'm trying to locate this non existent part or the component to fix the circuit board. the part number stamped on the housing for the board is #10052955 , any help out there. thanks
Attachment: IMG_2307.jpg (1.47 MB) 3 View(s)
Attachment: IMG_2305.jpg (2.06 MB) 2 View(s)
Edited by tractordrivindan on 07-01-20 08:09 PM. Reason for edit: No reason given.
tractordrivindan
tractordrivindan
Reg: 04-05-19
06-30-20 11:04 AM - Post#2797546
    In response to tractordrivindan
could use some help , if anyone has a 1991 r2500 the fuel pump cycle control located next to the steering column has a circuit board that can pulls out. i need part numbers off a component to be able to repair this board. thanks for any and all help
06-30-20 11:33 AM - Post#2797548
Interesting I found information that the module was replaced with OEM part number:
10052973
U.S. market on July 1, 2010
Does the connection fit?
'08 GMC Acadia 3.6L SLE
tractordrivindan
tractordrivindan
Reg: 04-05-19
06-30-20 03:10 PM - Post#2797569
thanks, i have that number also,still lost in the fog.
if the circuit board is the same then i can insert it into the little black box it is inserted in.
Edited by tractordrivindan on 06-30-20 03:15 PM. Reason for edit: No reason given.
06-30-20 06:11 PM - Post#2797584
When parts are superseded, they are improved. The board is probably upgraded so the soldered points don't break. The '90 trucks had problems with their wiper boards. A good mechanic could fix his own board. Or an upgrade was installed. Post pics once you have them taken apart.
tractordrivindan
tractordrivindan
Reg: 04-05-19
07-01-20 08:05 PM - Post#2797686
the problem i have is with one of the components that is swelling and the material is oozing out. its hard to read the numbers on the component to be able to find it at the local electronic warehouse. the number is the key.
tractordrivindan
tractordrivindan
Reg: 04-05-19
07-01-20 08:52 PM - Post#2797688
after i googled the number on the back of the circuit board #p9126-3 , then going to the site (67-72 chevytrucks.com) old posts from 2004 to 2010 pooped up with the info that i may need (post #6). the part in question is a voltage regulator.the post was talking about earlier model years but may have made some changes by the time it made it to my 91.hope this info may help others in the future. thanks for every ones help.
Attachment: IMG_2324.jpg (4.41 MB) 0 View(s)
Edited by tractordrivindan on 07-01-20 09:05 PM. Reason for edit: No reason given.
07-02-20 05:52 AM - Post#2797701
Can the voltage regulator be replaced? Nice find on information. Thanks for posting. The information will be archived here too.
tractordrivindan
tractordrivindan
Reg: 04-05-19
07-02-20 06:13 AM - Post#2797703
working on it with a electronic parts warehouse, will post my findings.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
07-03-20 05:57 PM - Post#2797826
Unplug it and move on. That is also called the Hot Fuel Module and used in the fullsize G-vans. Mine nearly burned down a G-van I had years ago. Will not make one bit of difference in the way it runs to remove it and throw it in the trash. Basically its a timer module that keeps the fuel pump running for a short time after shutting off the engine.
Edited by 1983G20Van on 07-03-20 05:58 PM. Reason for edit: No reason given.
tractordrivindan
tractordrivindan
Reg: 04-05-19
07-06-20 08:07 PM - Post#2798087
    In response to 1983G20Van
picked up the repaired circuit board, tech charged me $50.00, removed the part,back tested to determine the reduced voltage was 5v then head down to the electronic warehouse for a $4.00 part. part number is readable.
Attachment: IMG_2328.jpg (1.7 MB) 0 View(s)
Edited by tractordrivindan on 07-06-20 08:10 PM. Reason for edit: No reason given.
tractordrivindan
tractordrivindan
Reg: 04-05-19
07-06-20 08:19 PM - Post#2798090
to 1983 G20 van tech says part could have started failing due to a short somewhere. my concern would be that this small part way be first in line then working its way to the $850.00 ecm.
Edited by tractordrivindan on 07-06-20 08:22 PM. Reason for edit: No reason given.
Execution time: 0.097 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:36 PM
