Username Post: High pressure oil gauge for '50 car instrument cluster?        (Topic#361558)
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
06-29-20 09:36 AM - Post#2797442
Can anyone recommend a higher pressure oil gauge to replace the one in my stock '50 Styleline Deluxe instrument cluster? The hot rodded 261 I'm swapping in has a high pressure oil pump. I'm pretty sure someone(s) have done this swap before and I would like to pick their brains!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
chevcpe
chevcpe
Loc: Colorado
Reg: 10-15-03
06-29-20 04:09 PM - Post#2797477
    In response to mahlmann
Hi Mike,
I’m not certain of your concerns. I have two ’51 Chevys, one with a full pressure 235 and the pickup with a pretty stout 261, fuel injected. Both vehicles have the original oil pressure gauges and I have never had any issues. I guess I never worry about having too much oil pressure, only about having too little oil pressure. Both vehicles run, cold or hot, with the pressure gauges “pegged”, which is at least 30 lbs. P.S.I.
1951 Business Coupe w/ '54 235
1951 3100 5-Window w/' 62 Fuel Injected 261 and OD
BAJohnny
Loc: Kentucky
Reg: 04-04-13
06-29-20 08:09 PM - Post#2797493
    In response to chevcpe
What kind of fuel injection are you using?
1953 BelAir 2dr Sedan
1953 BelAir 2dr Hardtop
06-29-20 09:24 PM - Post#2797499
    In response to BAJohnny
I'm betting Williamson gauges, in Chester, Arkansas has dealt with this problem before.
Williamson's Instruments
eplantage
Loc: Southern MN
Reg: 03-15-04
06-30-20 05:03 AM - Post#2797506
Weren't there 60psi oil pressure gauges used in vehicles equipped with powerglide transmissions? Not sure what year that was started.
Age: 66 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
06-30-20 05:32 AM - Post#2797507
    In response to eplantage
The '53 Power Glide cars were the first to get 60 lb gauges. They were equipped with the new full oil pressure 235s.
Just Slightly Abrasive
Edited by 40grit on 06-30-20 05:34 AM. Reason for edit: No reason given.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
06-30-20 07:49 AM - Post#2797522
I'm not sure how similar the a 49-50 30 lb. gauge workings are to a 53 PowerGlide and up 60 lb. gauge...so that one could possibly attach the 49-50 face to the 53 and up 60 lb. gauge. I do know that the 49-50 and 47-53 truck look exactly the same aside from the face. I will say this...the rivet spacing that holds the face of a '49 - '50 face is EXACTLY the same [1-1/8"] as a 47-53 truck 30 lb. The 60 lb. truck gauges are configured the same as the 30 lbs. truck gauges. The truck presents a problem however, in that it is basically an inverted gauge. I do not have a 60 lb. '53 PowerGlide or newer gauge to compare....those gauges are however in the same orientation. Again, unfortunately, not a definative answer, but to me, it seems very doable as long as the inner workings are similar [which they probably are, just calibrated differently] and the rivet spacing is the same [1-1/8" is the magic number].
If it were me and I wanted an original look, that is how I would attack it. I would procure a 1953 PowerGlide or 54 oil pressure gauge and then compare. If the spacing is correct, I would remove the black face and re-attach the silver '49-'50 face using small brass hobby screws ans nuts, paint the needle red, and call it good. The only problem would be that your plastic lens would still have the 30 lb. number but not sure if that would be an issue or not.
UPDATE: I did have the opportunity to measure the distance between the rivets on a '53-'54 TEMP gauge and the distance was 1-1/8" so I assume the OIL gauge would be the same.
1951 Fleetline Preservation
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
06-30-20 08:44 AM - Post#2797535
    In response to RAM_51
Sounds to me as if he wants to keep the stock configuration on the dash. If it were me and I was concerned with the high reading then I would install an after market Gage under the dash in order to know what the high was and use the stock one to keep track of things while driving as it would show any low pressure that might develop.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
06-30-20 10:40 AM - Post#2797545
I ended up putting a '53 standard gauge in my '54 Powerglide, knowing that the pressure would hang right around 30, near the max of the gauge. It seemed like a reasonable compromise; you'd have to really look close to know that it was from a different model of car.
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
arkansas
Loc: arkansas
Reg: 09-26-06
06-30-20 01:20 PM - Post#2797557
    In response to dsacton
I bought a set of those aftermarket gauges at Advanced Auto. Took the gauge itself out of the housing and trimmed the face to fit the 49 chevy cluster for my coupe. Had to do some "rigging" to get it to fit just right. Painted the face silver and installed it. I think the max on the new one was 80 psi. I sort of painted the 3 on the 30 into an 8 and called it good. Not show quality, but it works. did the same thing with the ammeter and temp gauge too.
1949 Deluxe Coupe 400sbc, 700r4, 3.73 posi
1949 4 door Fleetline Special, all original
1949 2 door Fleetline Deluxe rustbucket parts
1971 Chevy 1/2 ton shortwheel base, 250 I6, 2004r, underconstruction
1926 Ford T bucket, 250 Chevy, T350 tranny
40grit
Reg: 07-08-13
06-30-20 01:49 PM - Post#2797560
    In response to arkansas
I bought a cheap volt gauge to convert my ammeter with but have not done anything with it yet.
I hope to make it look stock.
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
06-30-20 06:07 PM - Post#2797583
    In response to 40grit
You guys bring up two things I’ve worried about. 1) pegging the oil gauge and having it like burst or something and 2) the ammeter. I followed factory wiring with my own tweaks when I wired my car in 2015 but people have me freaked out that the ammeter will burn up. It’s likely to get deleted
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
06-30-20 08:43 PM - Post#2797595
    In response to drew1987
I personally don't care for amp meters(can short out,and start a fire). I custom built my gauge panel when refurbing my BelAir. Speedo,tach,oil, temp,gas,and VOLT METER,also the turn indicators,and Hi Low beam
http://pic100.picturetrail.com/VOL782/13320185/241...
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
Edited by Lead sled on 07-01-20 02:25 PM. Reason for edit: No reason given.
drew1987
drew1987
Reg: 02-23-14
07-03-20 04:34 AM - Post#2797770
    In response to Lead sled
That looks great! We 50 folks can’t fit it all though:(
Member:
Execution time: 0.092 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:41 PM
