Username Post: timing taboo 350engine        (Topic#361552)
dickydevil
Reg: 06-28-20
06-28-20 03:26 PM - Post#2797402
how do i get the correct aftermarket timing tab for 1 1984 350 engine #1409368?
Edited by dickydevil on 06-28-20 03:27 PM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-28-20 05:29 PM - Post#2797410
    In response to dickydevil
you first verify the true TDC
then buy the correct matching timing tab and or timing tape or marked damper etc.
don,t guess verify TDC .. read the links
then buy and install the correct timing tab/ damper or timing tape
Edited by grumpyvette on 06-28-20 05:36 PM. Reason for edit: No reason given.
Execution time: 0.111 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:40 AM
