Username Post: Rustproofing        (Topic#361544)
belairbob50
Loc: OH where rust never sleep...
Reg: 03-17-13
06-27-20 05:34 PM - Post#2797335
I would like to rustproof the insides of the rockers on my 1950. I do not want undercoating. What products have you used? Thanks
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
06-27-20 10:19 PM - Post#2797349
    In response to belairbob50
I've never used them, so no personal knowledge, but Ziebart was a BIG name in rust protection when I grew up in nothern Ohio.
1951 Fleetline Preservation
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
06-28-20 10:08 AM - Post#2797371
    In response to RAM_51
Do a search for Cavity Wax. it is sprayed into the cavities and migrates into the nooks, crannies, and crevises.
Just Slightly Abrasive
06-28-20 10:31 AM - Post#2797373
    In response to 40grit
X2 on cavity wax. It is available in spray cans and you can get different length wands with a tip that sprays in basically 360 degrees to reach all areas.
1957 Cameo Carrier
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
06-28-20 03:19 PM - Post#2797400
    In response to wagonman100
Another thing that you might try from Eastwood
https://www.eastwood.com/internal-frame-coatin g-ae...
Doug
belairbob50
Reg: 03-17-13
06-28-20 05:15 PM - Post#2797407
    In response to Doug52sedandelivery
I have used the Eastwood Internal Frame Paint with good success. I bought the green color so I could see the paint coming out of the black frame. I have also used Honey Coat on the inside of the doors, rear quarters and the trunk. I plan on contacting the company on Monday to see if this product is usable inside the rockers. Honey Coat never dries and you don't want to use it in a fender well because road debris will stick to it.
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
06-28-20 07:57 PM - Post#2797416
I also used the Eastwood product(green) for the inner rockers.
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
Execution time: 0.099 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:59 PM
