Username Post: Fan belt for '66 Big Block        (Topic#361542)
66cayne
66cayne
Reg: 08-06-08
06-27-20 12:17 PM - Post#2797310
I need a new fan belt for my '66 Biscayne. Its a big block with factory pulleys. My current belt is a Dayco 56015 11A1420. Per the specs it is 56" long. Its a little too long requiring the alternator to be moved all the way to the end of the adjustment slot on the bracket. What are you guys running? And does anyone know of a website that can ID a belt based on V-belt length/width/pitch? Thanks
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
06-27-20 01:51 PM - Post#2797315
    In response to 66cayne
The part number tells you the length, width etc.
11A1420 = 11mm wide (7/16") - A section - 1420mm long (56")
Try an 11A1395 or 11A1380
Steve
1966 Caprice 396 496 496mkII TH400
66cayne
66cayne
Reg: 08-06-08
06-28-20 01:56 PM - Post#2797392
    In response to Crusty66
Thanks, I learned something!
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
06-29-20 09:24 AM - Post#2797440
I used one from Napa 25-7570 or gates 7570. The first one I bought was too long also.
Went thru 3-4 to find the correct setup, they were cheap on Rock auto.
https://www.rockauto.com/en/catalog/chevrolet, 1966...
Ted
Edited by brickwhite on 06-29-20 09:32 AM. Reason for edit: No reason given.
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
06-29-20 12:13 PM - Post#2797450
    In response to brickwhite
and of course the 7570 means
"7" = 7/16" wide
570 = 57" long
In 66Cayne's example 11A1420 is the same as 7560
Steve
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
06-29-20 02:20 PM - Post#2797460
This thread is why I always carry the belt and radiator hose numbers with me on road trip. You could throw a belt and not be able to find it.
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
06-29-20 08:36 PM - Post#2797498
    In response to Tri5man
I always carry spare belts for my Chevy - chances of getting the right ones at a local store are low in my country.
Steve
Execution time: 0.126 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:08 AM
