Username Post: Can I add sound to after market turn signal switch?        (Topic#361538)
hand123
Reg: 07-15-12
06-26-20 08:49 PM - Post#2797276
Hello,
I have a 1950 Fleetline with an aftermarket turn signal switch on the column and signal relay under the dash. The switch on the column does not make a sound when the signal is engaged. The switch does not self cancel. The relay makes a little sound. I would like to add a louder sound so I can hear the turn signal when I'm driving. Is there any aftermarket sound device I can add? Can you direct me to device names and / or links?
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
06-27-20 02:01 AM - Post#2797283
    In response to hand123
Here:
http://www.turnalarm.com/
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
McCargar
McCargar
Reg: 12-07-11
06-27-20 08:17 AM - Post#2797295
Search ebay for "Continuous Sound Piezo Buzzers"
I know it says 12v but works well on 6v and they are cheap.
lobucrod
lobucrod
Loc: Slaton, TX
Reg: 10-01-07
06-27-20 02:06 PM - Post#2797317
I had the same problem on my ‘50 sedan delivery. I went the now defunct radio shack and purchased the cheapest 12V buzzer they had. Wired to the pilot terminal of the 3 terminal flasher. It was way too loud so I wrapped some thin foam around it held on with a wrap of electrical tape. It’s still plenty loud. Don’t have to worry about leaving signals on.
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
hand123
Reg: 07-15-12
06-28-20 03:09 PM - Post#2797398
    In response to tommy49
Thanks for the Turn Alarm info. I looked at the relay I have in my car and was able to match a replacement on Turn Alarm. I ordered one today. Looking forward to it.
tommy49
tommy49
Reg: 09-28-12
06-28-20 03:34 PM - Post#2797403
Tommy
Execution time: 0.093 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:28 PM
