Username Post: 73 Chevy 250 EFI        (Topic#361536)
mean60impalagene
Loc: STOCKTON CA.
Reg: 01-31-13
06-26-20 05:49 PM - Post#2797265
I would like to know if a 2 barrel or 4 barrel would be better to install on this engine with the EFI. It will have a 200R4 behind it. Thank you
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
06-27-20 08:36 PM - Post#2797347
    In response to mean60impalagene
More data...what do you want to do, what is it in, what is ur gearing, stock?
A 2bbl TBI was big enough for a stock 350 and also the 4.3s.
Edited by Stinky on 06-27-20 08:43 PM. Reason for edit: No reason given.
mean60impalagene
Loc: STOCKTON CA.
Reg: 01-31-13
06-28-20 06:56 AM - Post#2797362
    In response to Stinky
I am planning to go Stock Chevy 250(rebuilt)200r4 and dialed in rear end. Question to people who have done EFI and 6 cylinder. The do and Don'ts t.i.a. :angeljavascript:void(0):
65_Impala
Reg: 12-29-02
06-28-20 05:27 PM - Post#2797408
Are you going to use stock TBI parts?
A couple of do's are to use a heated O2 and to make sure the pump is sump'ed or baffled so that it can never suck air.
mean60impalagene
Loc: STOCKTON CA.
Reg: 01-31-13
06-29-20 06:32 AM - Post#2797428
    In response to 65_Impala
I am looking at the Holley or a kit to put in a 1960 Chevy Impala with a Camaro 250 and 200r4 Thank you for any information.
Member #409
06-29-20 08:03 PM - Post#2797492
Unless you're going to do other mods like a bigger cam, porting the head, etc., the Holley 2 barrel throttle body injection should suit your needs, and will be a less complex install.
65_Impala
Reg: 12-29-02
07-01-20 07:48 PM - Post#2797685
Ya, the Sniper 2-barrel should be quite fine assuming it fits the intake on your engine.
Execution time: 0.094 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:07 PM
