Username Post: Any photos of splash pan for 60 V8 with power steering?        (Topic#361529)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
06-25-20 05:59 PM - Post#2797201
I need a pic of what I'm missing. I have a 60 V8 with power steering. I think it's called a splash pan.
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
06-25-20 08:47 PM - Post#2797211
    In response to Eth727
At some point GM discontinued using the engine shield and my understanding is because it was creating overheating in the engine compartment. These are the pieces that I have but I haven't reinstalled them as of yet and not sure that I will. The power steering hose bracket was attached to the shield and when they discontinue the shield the new bracket was attached at the steering box using the box bolts. This is the page on the shield from the assembly manual. Hope that this helps. Lamar
Attachment: IMG_0133.JPG (113.59 KB) 1 View(s)
Attachment: IMG_0134_-_Copy.JPG (939.06 KB) 1 View(s)
Attachment: IMG_0135.JPG (1023.71 KB) 1 View(s)
Attachment: engine_shield.jpg (1.29 MB) 1 View(s)
Edited by PLS on 06-29-20 07:07 AM. Reason for edit: Corrected hose bracket location
ragtp66
Reg: 12-09-07
06-25-20 09:23 PM - Post#2797217
Someone else may correct me if I am wrong but I thought the splash pans were discontinued after 1959.
Toys:
1987 Sea Ray Pachanga 22
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
06-25-20 11:35 PM - Post#2797223
    In response to ragtp66
Yeah so I had a splash pan installed on mine. I just got my car back from the body shop and noticed it was missing. Unfortunately it's now in Mexico and I probably won't get it back. I don't remember what it looked like but I know it covered the PS hoses because I had to remove the panel to get it.
I was going replace it because I don't like missing parts but it might be okay without it?
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
06-26-20 12:23 PM - Post#2797243
There were on both the '59 and '60. The way I understand it is they made 2 kinds. One for both the 235-6 and the 348 and one for the 283.
Not sure if it was for the whole year or not in '60 and also heard that they produced a bulletin on them, as PLS has indicated.
Member:
-National Impala Association
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
06-26-20 03:02 PM - Post#2797253
    In response to 62BillT
Since Lamar doesn't have his on and there was a bulletin about cancelling them, maybe I should leave it off especially if it keeps the car cooler. What do you guys think? Does anyone else have them on their 1960's.
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
06-27-20 11:30 AM - Post#2797304
If I had a '59 or '60, I wouldn't put a pan on either, especially if you drive it a lot in hot weather.
Member:
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
06-27-20 05:47 PM - Post#2797336
So I take it that 61-on nobody used them?
PLS
PLS
Reg: 06-07-12
06-27-20 07:42 PM - Post#2797345
I'm far from being an expert on the subject but I think that you would be safe in assuming that.
I don’t remember having a heating problem with the shields on but that was 40+ years ago and I can’t remember what I did this afternoon so I’m not going to reinstall them.
Here is a topic that I posted https://www.chevytalk.org/fusionbb/showtopic.php?t... and you can see in the picture that Jalapeno shared of the bracket that was used without engine shields installed.
You can see how neat that one looks and how mine sort of looks messy without the bracket.
I am going to try and find that bracket and install it. Jalapeno is the resident expert on power steering. Hope this helps. Lamar
Attachment: IMG_0142.JPG (722.01 KB) 2 View(s)
Attachment: IMG_0143__2_.JPG (727.85 KB) 0 View(s)
Is this bracket still installed on your car?
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
06-27-20 10:35 PM - Post#2797351
    In response to PLS
Yes I still have the PS bracket. It's so weird you don't have oil dripping underneath your car.
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
06-28-20 06:51 AM - Post#2797360
Correct. Used in '59 and part of '60. None in '61.
The 6cyl & 348 are the same because of the longer oil pan (deeper notch in the pan).
Verne
PLS
PLS
Reg: 06-07-12
06-28-20 06:52 AM - Post#2797361
I shouldn't say this because it will probably happen now but I don't have any oil leaks but I do have a leak from the old "glide" transmission
Attachment: IMG_0147.JPG (70.86 KB) 0 View(s)
This is after being parked about 2 1/2 weeks. I have to keep the drip pan under it.
Jalapeno
Member #252
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
06-28-20 10:01 AM - Post#2797370
    In response to Verne_Frantz
Verne
^^What Verne said.^^
Jalapeno
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
06-29-20 09:39 PM - Post#2797500
    In response to PLS
Hey did someone spill red wine?
Execution time: 0.099 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:31 PM
