Username Post: Worth of block and tranny        (Topic#361527)
rkandii
Reg: 10-05-07
06-25-20 05:48 PM - Post#2797198
What is a 2 barrel 283 and its powerglide worth. They are both rebuildable. Guy is wanting correct coded set for his impala.
rkandii
Reg: 10-05-07
06-25-20 05:53 PM - Post#2797200
    In response to rkandii
Ooops. 1958.
ragtp66
Reg: 12-09-07
06-25-20 09:31 PM - Post#2797218
A couple hundred bucks each for engine and trans depending on if your including all the linkage for trans and slip yoke. The same for engine a lil more if your including exhaust manifolds, generator, air cleaner, water pump etc. You have found the needle in the haystack; a buyer LOOKING for what you have. To anyone else it basically has scrap value.
Toys:
1987 Sea Ray Pachanga 22
Execution time: 0.467 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:47 PM
