Username Post: 58 Bel-Air Turn Signal Bezel Removal        (Topic#361506)
Stingray9190
Stingray9190
Reg: 03-03-14
06-24-20 01:02 PM - Post#2797103
Hello..Does anyone have a quick way to remove the turnsignal bezels on a 58 Bel Air? I am having a hard time getting my hand inbetween the grill and headlights. Any other way? RayJ
Delray_58
Loc: Scotts Valley, CA
Reg: 03-20-10
06-27-20 09:08 AM - Post#2797297
    In response to Stingray9190
I've removed the grille completely from the surrounding sheetmetal, then removed the bezels from the grille. First step is to remove the hood latch and crossbar over the grille, then the rest of the grille bolts are pretty easy to access.
'58 Delray 283 3-speed OD
In the family since new
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
06-29-20 09:53 AM - Post#2797444
As I recall, I had to get behind the turn signal housing in order to remove it. Did not remove the grill. Was easily accessible from inside the wheel well after removing the inner fender panel at front of inner fender. Here's a link to an ebay ad showing a pic of the inner panel I'm talking about: Link
Stingray9190
Stingray9190
Reg: 03-03-14
06-29-20 03:04 PM - Post#2797464
    In response to Delray_58
Thanks for the advice. Appreciate it. RayJ
Stingray9190
Stingray9190
Reg: 03-03-14
06-29-20 03:05 PM - Post#2797466
    In response to JayChicago
Thanks...that is what I thought. Looked like there was a panel there but with all the undercoating I was unsure. Appreciate it. RayJ
Execution time: 0.132 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:18 PM
