Username Post: 86 fuel delivery problem        (Topic#361498)
Codym
Reg: 06-23-20
06-23-20 07:44 PM - Post#2797059
I’ve got a 86 Chevy c10. I just replaced the whole fuel system in the truck. Got everything put in and I’m having problems getting fuel to the carb. I’ve got an in-line fuel filter between the pump and carb. Once I start the truck, the fuel filter gets about 2 or 3 good pumps of fuel into and then no more. I’ve replaced the pump again and still same thing. I did try the ol trick with the full fuel can and empty one and it worked beautifully! But once I put everything back to normal, I still get 2 or 3 pumps and that’s it. Any ideas? Possible vacuum leak somewhere? I’m lost and can’t find the problem! Thanks in advance
06-24-20 12:26 PM - Post#2797101
    In response to Codym
Welcome to the site.
Please provide a few more details. What is the engine size? Is the fuel pump mechanical? Is the fuel filter metal enclosed? If so, it may only flow in one direction. What is the carb type? Are you using a dual fuel tank system? What kind of fuel line is installed between the pump and carb? My first guess is the fuel filter is installed backwards.
'08 GMC Acadia 3.6L SLE
Codym
Reg: 06-23-20
06-24-20 03:15 PM - Post#2797116
It’s got a 305 in it and a rebuilt 4bbl Holley carb. it does have a mechanical fuel pump and It does have a inline filter that’s clear and it’s in the right direction. I’ve checked it a million times just like everything else lol. I ended up going with a rubber fuel line from the pump to the carb for now. I had originally bought a new metal fuel line for it but i didn’t buy the correct one and I knew I was gonna change the carberator
06-25-20 06:30 AM - Post#2797145
Okay, is the carb new? Or did the carb previously work? Who rebuilt it? Is it an ordered rebuilt carb? A company rebuilt carb is normally tested before being sent out. Are the carb bowls filling? What is the carb model and part number?
On my truck, due to extensive modifications, I bent and routed my own fuel line. I have a metal encased in line fuel filter.
Your post will be moved to the Performance Section. Holley carb users will help you if the carb needs adjustments or changes.
IgnitionMan
Reg: 04-15-05
06-25-20 07:47 AM - Post#2797150
Clear filter, please post if the element inside it is a paper, or sintered bronze element.
If sintered bronze, they are directional, in that flow goes through the media ONE direction, stops the other way. We usually see these elements in the inlets to carbs.
Sintered elements also have a spring on one end, to allow for the fuel pressure to push a plugged, or installed backwards element off its inlet side seat, to continue to supply liquid past a plugged, or backwards installed element.
Just more info on a filter.
Codym
Reg: 06-23-20
06-25-20 09:21 AM - Post#2797157
    In response to IgnitionMan
Ok, I might of gotten y’all confused but that’s my fault sorry. The carb and fuel pump are fine. I hooked up a fuel line going into the pump Coming from a full gas can and then the return line going into an empty can and everything worked like they should. I had plenty of fuel getting to the filter and carb at that time. But when I hooked everything back up original there’s not much fuel going from the pump to the carb. So I’m guessing there’s something wrong somewhere from the tank to the pump. I’ve double, triple checked everything So far except the fuel tank cause it’s in a tight spot. Gonna pull the tank out in the next day or 2
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
06-25-20 02:18 PM - Post#2797182
RAN INTO A FEW OLD RUBBER FUEL LINES BEING CRACKED & SUCKING AIR FROM THE TANK FEED.ALSO I NEEDED A PRE BENT RUBBER FUEL LINE FROM THE HARD LINE TO THE FUEL PUMP. JUST USEING REG HOSE THE BEND WAS TIGHT & HAMPERED THE FUEL SUPPLY TO THE CARB .
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Codym
Reg: 06-23-20
06-25-20 02:26 PM - Post#2797184
    In response to TAT_2
That’s the thing, I’ve replaced all fuel lines in the truck and I’ve made sure there was nothing that was bent to much were it would restrict flow. The only thing that I can think of that might be the problem is the filler neck, the vent line next to it, or the fuel sending unit. I did replace the sending unit when I pulled the tank awhile back. And I cleaned the tank like crazy so there would be nothing that effect it. So I’m puzzled on why it get a few good pumps of fuel then it stops. But I think I’m gonna pull the tank this weekend cause that’s the only thing that I haven’t been able to double or triple check so far
TAT_2
TAT_2
Reg: 10-29-00
06-25-20 02:43 PM - Post#2797186
MIGHT BE A LONG SHOT BUT TRY RUNNING IT WITH THE GAS CAP REMOVED.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Codym
Reg: 06-23-20
06-25-20 02:45 PM - Post#2797187
Ok I’ll try that before I remove the tank. Thanks
06-25-20 02:58 PM - Post#2797188
Try the gas cap first, but it sounds like something is getting sucked into the pickup on the sending unit and stopping fuel flow from it.
1957 Cameo Carrier
Codym
Reg: 06-23-20
06-25-20 03:01 PM - Post#2797189
    In response to wagonman100
Ok I’ll try it. Thanks for the responses! I’ll let y’all know what happens and what I find out
06-26-20 06:12 AM - Post#2797228
Codym,
My next suggestion has been given. Remove the gas cap. Are they new or old gas caps? Our C10 trucks are known to stop fuel delivery with incorrect gas caps. Ok, sorry, I read all your initial information incorrectly. The Performance Section is probably our most helpful area. Everyone from newbies to seasoned mechanics are here.
Are you using a 3 port or 6 port switch valve? Can you hear the valve change positions when activated in the cab? Sometimes, the valve can get stuck. It has happened on my dual tank truck.
06-26-20 08:24 AM - Post#2797234
i dont understand 2-3 pumps? if you have a glass filter throw it away. fram makes plastic see throughs if you need to see your fuel. mechanical pump? try block off the return line.
Execution time: 0.091 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:46 PM
