Username Post: Air compressor pump removal and installation        (Topic#361490)
BG
Reg: 09-12-07
06-23-20 02:37 PM - Post#2797032
I’m getting a used Ingersoll Rand 5hp compressor with vertical 60 gallon tank and need to remove the motor and pump to transport and it’s really heavy. It has the cast iron pump and I’m wondering how difficult it will be to remove and reinstall? Thanks
06-23-20 02:48 PM - Post#2797036
    In response to BG
I’ve never removed the pump on a compressor, but I have removed a motor before. Neither should be difficult to remove. The motor is usually just mounted on a bracket welded to the tank. Take off the belt and the bolts holding the motor to the bracket. The pump should be mounted similarly and usually just have a tube connected to it that goes from the pump to the tank. That tube will have to be disconnected from either the pump or the tank.
1957 Cameo Carrier
BG
Reg: 09-12-07
06-23-20 03:05 PM - Post#2797040
    In response to wagonman100
I concerned about lowering the heavy pump and getting it back up on top of the tank, the motor isn’t very heavy.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
06-23-20 07:01 PM - Post#2797054
    In response to BG
Got an engine hoist? I used mine to lift & move my 60 gal comp, so lifting off the pump should be easy.
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
BG
Reg: 09-12-07
06-24-20 06:37 PM - Post#2797127
    In response to tommy49
I don’t have engine puller. I’m wondering if it could be lifted by 2 people or in general will it be too heavy?
BG
Reg: 09-12-07
06-25-20 06:31 PM - Post#2797203
    In response to BG
Moved it with pump installed but it was a job. At least it’s done
Execution time: 0.066 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:09 AM
