Username Post: Removing rear axles        (Topic#361477)
Chevy_Crazy
Chevy_Crazy
Loc: Newfoundland, Canada
Reg: 11-20-02
06-22-20 04:06 PM - Post#2796932
Hey guys, I've read several threads here about replacing rear axle bearings, but it never really says anything about removing the axles from the car.
I have removed the 4 bolts from the cover, and the lock washers. The cover doesn't seem to want to come off, and I've tried pulling the axle out with the cover in place and I'm not getting anywhere with it.....am I missing something??
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
06-22-20 05:03 PM - Post#2796933
    In response to Chevy_Crazy
I believe these are the same as my 58. Use a slide hammer. The bearings are pressed on to the axle with either 1 or 2 o-rings on the outside of the bearing. After years of being in there the usually need some help with the slide hammer.
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
06-22-20 05:04 PM - Post#2796934
you must have a slide hammer to remove axles. You will not have any luck without a slide hammer.
bolts to at least 3 studs to get the axles out of the center pumpkin.
The one I use is similar to this one.
https://www.amazon.com/OTC-7374-Slide-Hammer -Pulle...
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
Member #51
06-22-20 05:25 PM - Post#2796936
NO, you are NOT missing something!
As mention above, the CORRECT tool that is needed, and also shown in the link posted by Paul(PVS409), is an axle pulling slide hammer.
Many people have used several tricks ----------------- which sometimes work, and sometimes don't.
As you have already done, remove the 4 nuts on the back side of the brake backing plate, remove the brake drum, and attach the slide hammer with 3 lug nuts and hammer away. SOMETIMES, the axle pops right out with only 1-2 hits. And sometimes and may take several HARD whacks to get the bearing to come out of the end of the axle tube ---------- depending on how long it's been there and how much rust has developed between the bearing and the end of the axle tube.
Other methods which have been used by some people, involve removing the brake drum, turning it around backwards, install 3-5 lug nuts (not screwed all the way on) and then use the drum as a make-do slide hammer. Some people have used a length of chain, placed over 2 of the studs and secured with lug nuts, attached a heavy weight on the other end of the chain and whacked away. Frequently, some of the home spun methods work quite well to remove the axles. BUT, the best method is to use an axle puller slide hammer. MANY tools such as this can be rented from SOME auto parts stores, such as O'Reilly.
Bubpletop62
Loc: Bakersfield, CA
Reg: 03-21-06
06-22-20 05:38 PM - Post#2796938
You just got advice from the best forum members. IF the drums are NOT turning, they are either rusted to the shoes or adjusted out too far. Try turning the adjusting star so the shoes can go inward. Plus, there MIGHT be a ‘lip’ on the drum preventing the drum from coming off.
Dennis Bubp
Dennis Bubp
'62 Belair Sports Coupe
drbubp@hotmail.com
lone star
Reg: 08-24-08
06-22-20 05:57 PM - Post#2796942
You can get them out without a slide hammer. Done it several times. Harbor freight sells slide hammer if you want. Or autozone probably rents one.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
06-23-20 04:04 AM - Post#2796971
    In response to lone star
Joey, also search on here for postings by DZAUTO on axles, he has done extensive/detailed postings on this subject. Including which style bearings to use, how to remove bearings and install them, plus about some bearings have 1 o ring and some 2 o rings. Buy the right bearings made in Canada, USA, or Mexico and get a name brand. Don’t buy Chinese.
Member #2194
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
06-23-20 05:48 AM - Post#2796977
That brings back memories. Many years ago I used a chain to pull axles just as you described.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
Chevy_Crazy
Chevy_Crazy
Reg: 11-20-02
06-23-20 01:22 PM - Post#2797024
Got one side out. Now, two of the bolts were so rusted that after a couple quick yanks with the slide hammer they stayed in place....but the cover plate didn't. so now I have to find a replacement. Does anyone reproduce them?
pvs409
pvs409
Reg: 01-10-05
06-23-20 01:39 PM - Post#2797025
What year Chevy ?
Paul
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
06-23-20 02:40 PM - Post#2797034
No one makes replacement bearing retainer plates. Your best bet is to just buy a replacement axle. It might even come with a good bearing....
Verne
Chevy_Crazy
Chevy_Crazy
Reg: 11-20-02
06-23-20 02:55 PM - Post#2797038
    In response to pvs409
  • pvs409 Said:
What year Chevy ?
Paul
1962
Chevy_Crazy
Chevy_Crazy
Reg: 11-20-02
06-25-20 03:59 PM - Post#2797193
Hey Guys, I found some billet aluminum replacements from Dutchman axles. Works with stock axle, bearings, and drum brakes.
https://dutchmanaxles.com/58-64-chevy-axle-reta ine...
blkss64
Reg: 07-22-12
06-25-20 08:13 PM - Post#2797209
FYI, ZIP Corvette has a repro of the stamped steel (stock) version. If you’re into performance, by all means stay with what you found. The Corvette used the same part from 57-62
Edited by blkss64 on 06-25-20 08:15 PM. Reason for edit: No reason given.
DonSSDD
DonSSDD
Reg: 08-21-01
06-26-20 12:57 AM - Post#2797224
    In response to blkss64
Don’t forget to order the gasket as well.
Member #2194
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
06-26-20 08:00 AM - Post#2797232
    In response to DonSSDD
In a pinch and if your lucky and strong, Ive seen my dad use a piece of 2 ft long piece of chain over 2 of the lugs with nuts on them and a X type lug nut wrench and it work.
Put the chain on then put the x wrench thru and slam it just like a slide hammer.
Chevy_Crazy
Chevy_Crazy
Reg: 11-20-02
06-26-20 02:16 PM - Post#2797250
    In response to turbo38s10
I ordered the billet piece. They were willing to ship it so I'd receive it on Monday. That'll get me back on the road, I'm going to order another one and change the other side when I get it.
Execution time: 0.095 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:24 PM
