Username Post: What is the color of Trunk Torsion Rods?        (Topic#361432)
carolinakid
carolinakid
Loc: Erwin NC
Reg: 08-27-03
06-19-20 05:03 PM - Post#2796727
What color are the trunk torsion rods suppose to be?
Body Color or trunk Splatter paint color. Same question for the trunk Hinge Boxes (where the trunk hinges slide in and out of)Thanks
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
06-20-20 07:15 AM - Post#2796767
    In response to carolinakid
On my '65 (Doraville car, unrestored) both were spatter paint.
1953 3104 1/2 Ton Truck
1965 Impala SS 327/M20
1965 Chevelle SS 327/M20
VCCA #47487
AACA #446449
ALPCA #12906
BillM89
Reg: 01-22-20
06-20-20 03:36 PM - Post#2796794
    In response to bajones238
Hello, I also have an unrestored 65 Doraville SS. Both the trunk torsion rods and housings are trunk spatter.
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
06-20-20 06:33 PM - Post#2796806
    In response to BillM89
Did they hit the rubber anti rattle sleeves too, or did they go on after paint?
Ryan
Build date Dec. 21 '64 Oshawa
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
06-20-20 06:52 PM - Post#2796811
    In response to Oshawa65SS
As mentioned here before, on the Canadian built cars the firewall and trunk were body color.
Steve
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
Oshawa65SS
Reg: 09-22-14
06-20-20 09:54 PM - Post#2796819
    In response to steve65
I got that Steve, but still wondering if the rubber anti-rattle sleeves went on before or after paint be it spatter or body color.
I guess I should say colour since body paint there is Canada only.
Ryan
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
06-21-20 06:00 PM - Post#2796873
The rubber on my '66 did not have any paint on it.
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
06-22-20 11:31 AM - Post#2796919
Ryan:
Taking a closer look in the trunk of my '65, it appears that the torsion rods first had the rubber sleeve installed, then were painted body color (with some overspray on the rubber sleeve), then were spatter-painted at the ends near the hinges.
VCCA #47487
AACA #446449
ALPCA #12906
Oshawa65SS
Reg: 09-22-14
06-23-20 12:25 AM - Post#2796966
Since there's a difference here between two original cars, I should have asked if the rod underneath the rubber is unpainted, that would cinch whether they go on before or after paint.
Ryan
jktucker92
jktucker92
Reg: 02-05-17
06-23-20 09:00 AM - Post#2796996
I can't be certain of anything because my car was re-painted in the 80's when I was 16, and then I repainted it again 3 years ago. I do know that the rubber sleeve had a little overspray, but it was definitely the bright white of the 80's repaint, not the original Ermine white. As I recall, there wasn't much paint on the torsion rods, and I thought they looked like they weren't purposely painted either body color or trunk spatter. I did repaint them black, being careful not to paint the rubber part, which meant I painted the one with the rubber sleeve one half at a time. My car is a convertible, so the painting pattern may not have caused as much overspray on them. I don't believe you could remove the rubber sleeve on my car. The rubber isn't flexible enough to go around the bend. If I had to guess, the torsion rod and rubber were likely installed prior to painting, and overspray of both the trunk spatter and body color was common on both components. Below is a link with a few pictures of a '59 GM car being painted.
http://theoldmotor.com/?p=175986
Execution time: 0.132 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:00 PM
