Username Post: shifter---4 speed        (Topic#361430)
Mdm57
Reg: 12-17-18
06-19-20 02:31 PM - Post#2796721
just curious---you guys with 4 speeds--what shifter are you running tks
55MAS
Loc: North Coast, USA
Reg: 12-19-01
06-20-20 06:42 AM - Post#2796762
    In response to Mdm57
It depends on transmission model and seat(s) that you have.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
06-20-20 06:59 AM - Post#2796763
Hurst competition plus.
Pete
06-20-20 10:57 AM - Post#2796783
long
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
06-20-20 02:35 PM - Post#2796790
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
Member #409
06-20-20 05:05 PM - Post#2796803
    In response to Lead sled
If you have a bench seat, you need to get a Hurst shifter that's specific for 55-57 Chevys with a bench seat. There are installation kits for Muncies, Borg Warners, and Saginaws that can be used with this shifter.
If you have bucket seats, you can use almost any shifter.
Bubpletop62
Loc: Bakersfield, CA
Reg: 03-21-06
06-28-20 12:06 PM - Post#2797378
    In response to Rick_L
On my ‘55 2dr bench seat, the shifter is Hurst Competition, however, it is for a ‘66-‘67 Nova. The trans is a Muncie 4sp. Now, the shift gate is set in the ‘forward’ position because that is Nova. The handle fit perfect (about two inches in front of the seat). The older style for this application has a ‘horseshoe’ shift handle and the gate is set in the ‘back’ position. The shift handle actually sits UNDER the front of the seat and looks terrible.
Just a thought.
Dennis Bubp
Dennis Bubp
'62 Belair Sports Coupe
drbubp@hotmail.com
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
06-28-20 02:28 PM - Post#2797395
    In response to Bubpletop62
This is just a FYI; most Hurst shifter "towers" are virtually the same. Some have a longer or curved reverse lever. Don't buy a bolt on stick style tower assembly, and then buy the Hurst 55-57 style curved shifter stick thinking it'll fit like the welded-on stick of the 55-57 shifters. Although it looks the same, it places the shifter stick higher up, and it will make contact with the lower edge of a bench seat. Learned that the hard way after buying a new shifter stick ($108.00!), non-returnable after the package was opened. On my "spare" 327, and Borg-Warner Super T-10, the shifter was originally a MOPAR pistol grip with a push-in stick. Gave the stick to a MOPAR friend, drilled a couple of holes in the stick mount, and bolted a straight Hurst stick on. The 56 Sedan Delivery has 68 Chevelle SS bucket seats, that I was going to replace with a bench seat. Changed my mind after the bolt-on, curved stick issue.
I am Butch/56sedandelivery.
Member #409
06-28-20 06:19 PM - Post#2797412
Virtually all Competition Plus Hurst shifters use a bolt on stick.
The one big exception is the one for a 55-57 Chevy. THIS STICK DOES NOT BOLT ON. It goes down into the guts of the shifter, same as the stub with 2 bolt holes on the other shifters.
gordy
gordy
Loc: Seal Beach, California
Reg: 05-04-05
06-28-20 10:17 PM - Post#2797418
I agree with Dennis. I've used the Nova shifter also. It moves the shifter forward away from the seat and then I get the bolt in reproduction 59-62 shift handle which gives an old school factory look along with room to move the seat forward if need be. It requires using a Muncie with tail shaft that has the speedo connection on the passenger side.
Gordy
'55 Delray
'55 210 2 door
'56 Convertible
'56 Nomad
'56 150 wagon
55MAS
Reg: 12-19-01
06-29-20 01:37 PM - Post#2797454
    In response to gordy
Gordy
Can the seat be moved to the FULL forward position with the shifter being fully functional?
gordy
gordy
Reg: 05-04-05
06-29-20 01:59 PM - Post#2797456
    In response to 55MAS
  • 55MAS Said:
Gordy
Well, I would have to check that. I'm 6'3" so I don't need to move it but, my wife is 5'5" and she can move it up enough to drive it fine.
Gordy
'55 Delray
'55 210 2 door
'56 Convertible
'56 Nomad
'56 150 wagon
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
06-29-20 11:14 PM - Post#2797501
Look up Hurst #5388620 stick;p it's the so-called Tri-Five, bolt-on, bench seat stick, that does't really fit/work with the bolt-on Hurst tower assembly. That's all I was saying. Maybe someone else has experienced this? I am Butch/56sedandelivery.
Member #409
06-30-20 12:51 PM - Post#2797552
So called is the key word. The Hurst description does not mention 55-57 Chevy.
The stick will be too high to fit under a stock bench seat as you said.
Pistol
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
07-04-20 08:30 AM - Post#2797860
Hurst competition
hole for floor
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics
55MAS
Reg: 12-19-01
07-04-20 02:47 PM - Post#2797901
  • gordy Said:
  • 55MAS Said:
Gordy
Gordy
Hey Gordy, how is that check coming?
Execution time: 0.138 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:30 PM
