Username Post: Hooker 2457 ground clearance        (Topic#361427)
jeff198901
Reg: 09-16-17
06-19-20 10:09 AM - Post#2796709
I have a friend that is wondering what the ground clearance is like for the hooker 2457 headers? I have them on my car but my car is on the shop and I have never actually measured
Thanks!
Jeff
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
06-19-20 02:24 PM - Post#2796720
    In response to jeff198901
I'll be surprised if anyone actually measures.
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
06-19-20 02:57 PM - Post#2796723
    In response to sz0k30
I did actually measure mine cause they dragged every time I pulled into my old underground parking lot.
Unfortunately I don'y remember where I wrote it down.
Story of my life, actually. LOL
Steve
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
pro552000
Reg: 10-09-15
06-20-20 08:47 PM - Post#2796814
    In response to steve65
So I actually just ran out and measured mine. Here are the stats on my car. 66 Caprice. I am running a Chevrolet performance 502 iron block and iron heads stock small block motor mounts. My 2457 headers hang down 4 1/2 inches from the bottom of the rocker panel to the bottom of the header collector flange. The top of the collector is 1 3/4 inches down from the floor of the car. One of the issues with header fitment in these cars is the heads that are on the engine. Some of the performance heads have a higher exhaust port location than stock heads do. As for scraping the headers on the ground. My car is lowered so that does effect that. Hope this helps.
Loren.
jeff198901
Reg: 09-16-17
06-21-20 09:03 PM - Post#2796880
    In response to pro552000
Thank you! Do small block mounts tend to sit a motor lower or higher?
pro552000
Reg: 10-09-15
06-22-20 07:05 AM - Post#2796900
If I remember right. The small block stands were higher. If you do some searching in this section you should be able to find the answer.
Loren.
Execution time: 0.156 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:21 PM
