 Page 2 of 2 <12
Username Post: Air ride install question/tips        (Topic#361418)
Adam63impala
Adam63impala
Loc: From Memphis to Florida
Reg: 12-01-15
06-24-20 01:58 PM - Post#2797108
    In response to mlsully
The bulkhead fittings I need would be 1/2" fittings if im using 1/2" line ?
Adam63impala
Adam63impala
Reg: 12-01-15
06-24-20 02:05 PM - Post#2797110
Will I need to use the loctite thread sealer on the threads going into the push in type connectors too ?
mlsully
Loc: Louisiana
Reg: 04-10-20
06-25-20 05:42 AM - Post#2797136
    In response to Adam63impala
yes, if using 1/2 air line you need 1/2 push to connect fittings. Here is an example of the bulkhead unions: https://www.bagriders.com/fittings/push-to-conn ect...
Also to your other post, you will use thread sealer on every threaded fitting.
Adam63impala
Adam63impala
Reg: 12-01-15
06-25-20 05:49 AM - Post#2797137
Awesome thank you my man !! Will be tackling this project very soon ! I have the confidence from these forums and doing alot of research .
Adam63impala
Adam63impala
Reg: 12-01-15
06-25-20 05:53 AM - Post#2797140
I already have some permatex high temp thread seeler , will this work or should I get the loctite 545?
mlsully
Loc: Louisiana
Reg: 04-10-20
06-25-20 06:48 AM - Post#2797146
I have never used that sealer, so I don't know if it will work the same. The loctite 545 is what most trusted installers use, so I would consider that the industry standard.
Adam63impala
Adam63impala
Reg: 12-01-15
06-25-20 10:09 AM - Post#2797163
Okay cool . Thanks for all your input ! Have you installed air ride on impalas
mlsully
Loc: Louisiana
Reg: 04-10-20
06-25-20 10:32 AM - Post#2797166
Yes, I installed air ride on my 1962 impala. No issues after a year so far.
Adam63impala
Adam63impala
Reg: 12-01-15
06-28-20 03:20 AM - Post#2797352
Good to know ! Seems the key is making sure no air leaks.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
06-28-20 09:20 AM - Post#2797368
Your right, obviously air loss is the biggest problem with air ride. The same thing happens if the compressor or bag fails you don't get too far.
Adam63impala
Adam63impala
Reg: 12-01-15
06-28-20 11:27 AM - Post#2797376
    In response to Tri5man
Duh..
Lol????
Tri5man
Tri5man
Reg: 06-26-07
06-29-20 02:05 PM - Post#2797459
I'm still having trouble with paying someone at least $4,000.00 to do an air ride installation. Sure helps to do your own work.
Adam63impala
Adam63impala
Reg: 12-01-15
06-29-20 03:54 PM - Post#2797472
I was quoted $750 . But doing myself. Did you remove all bump stops?
Adam63impala
Adam63impala
Reg: 12-01-15
06-29-20 03:55 PM - Post#2797473
That was sun coast customs . They specialize in air/hydraulics
Adam63impala
Adam63impala
Reg: 12-01-15
06-29-20 11:17 PM - Post#2797502
Guessing i will remove all the bump stops ?
mlsully
Loc: Louisiana
Reg: 04-10-20
06-30-20 06:46 AM - Post#2797513
yes, the factory bump stops will be removed.
Adam63impala
Adam63impala
Reg: 12-01-15
07-04-20 12:11 PM - Post#2797883
Okay cool. As soon as Boris ships my kit out I'll be installing! Ordered a Chad Criss Billet Manifold from him as well .
 Page 2 of 2 <12
Execution time: 0.073 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:08 AM
