Username Post: 2 Quick Questions        (Topic#361412)
SteveW
Loc: Shreveport
Reg: 04-24-02
06-17-20 06:40 PM - Post#2796605
Wondering if anybody is using a Mini starter
what have you found to be the best one for handling the heat from headers and a high torque 355 motor? I don't think the one on there now could turn a hot drill bit in a bucket of Lard.
Powermaster
Proform
Other?
Edited by SteveW on 06-17-20 06:41 PM. Reason for edit: No reason given.
Member #409
06-17-20 07:47 PM - Post#2796609
    In response to SteveW
A mini starter should be less sensitive to heat than an OEM starter. What are your symptoms? How close is the starter to exhaust?
SteveW
Loc: Shreveport
Reg: 04-24-02
06-17-20 11:06 PM - Post#2796620
    In response to Rick_L
Hello Rick. This is on my sons car he told me its a cheap mini starter off brand that has no name on it. He told me his 355 motor turns over really slow .I told him his timing may be off some. He said it has always turned over slow but ran. But now its even slower. He put in new battery and heat shield to cover headers still slow. Replaced cables and even pulled out all plugs and tried, still turning over slow even with second new battery. He's looking at getting another starter next. Both battery's he bought have 800 cca. I don't think its binding around the transmission . I was asking so I can call him and let him know what you guys think and if you could say what brand starter would be good with close headers . Motor is suppose to have over 400 HP.
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
06-18-20 05:49 AM - Post#2796635
I had 3 cars with BBC's & a 57 Chevy with a SBC with a built 350. I have had the GM mini starters on all the cars for years with never any problems or starting issues.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
06-18-20 07:37 AM - Post#2796647
Voltage drop could be contributing to you issue. Heat from your headers will amplify your voltage drop as well.
This can be solved by installing a relay for your starter.
Do some research here at madelectical.com
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
WagonCrazy
WagonCrazy
Reg: 06-07-05
06-18-20 04:52 PM - Post#2796680
    In response to kingkreeton
Check the condition of the wire between the battery + and the starter. Check the cleanliness of the connections on each end of the wire. Often times, they get oxidized, brittle, and begin NOT to transfer electrons with such volume. Don't rule it out...check it thoroughly.
Execution time: 0.186 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:00 AM
