Username Post: Wiring tach to hei        (Topic#361410)
65DJF
Reg: 10-01-17
06-17-20 02:38 PM - Post#2796597
I am in the process of wiring a Bosch Sport II tach to my 1965 Impala SS. I purchased an accel pigtail to go along with the installation. My question is, do I have to run the red wire from the tach to my fuse box ignition source, or with this pigtail , can I just run the red wire from the tach directly to the pigtail on the hei distributor labeled batt?
MarkISS
MarkISS
Loc: Brevard, NC
Reg: 05-14-18
06-18-20 05:14 AM - Post#2796631
    In response to 65DJF
If the red wire is "Pwr In" when key is in "On", I'd think any pwr source that is only hot during "pwr on" would be just fine... +12V is +12V
Mark
Mark - Brevard, NC - 66 Impala SS RestoMod
>>My detailed build thread link <<
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
07-04-20 08:46 PM - Post#2797922
    In response to MarkISS
Don't know about different HEI units but mine has two connections for the pig tails. One is for Batt(12v) and mine is wired to IGN at the ignition switch).
The other connection on the HEI is for the tach and, logically, it goes to the tach. The tach can also get its 12v from the IGN terminal. There may also be another 12v input on the tach for the lens lamp and it should likely be wired to a source that controls the interior lighting.
Note: The connectors at the HEI are identical, although to distinguish them properly they are typically different colors and usually come with different color wires. However, Classic Industries (at least) make a one piece two wire connector, that when properly installed, will eliminate the chance of later plugging the tach lead into 12v.
Regards,
Execution time: 0.153 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:20 PM
