Username Post: 2012 WT 1500 CONDENSER        (Topic#361347)
IBGM
IBGM
Loc: Silvertown, Ma.
Reg: 12-03-03
06-11-20 07:56 AM - Post#2796143
I have a 2012 5.3 WT1500 pick up. I need to change the condenser, does anyone have any tips on how to do get the old one out? Any shortcuts? Surprisingly little info on the internet about this. Appreciate any and all info!! I tried the search, but came up empty.
06-11-20 03:19 PM - Post#2796166
    In response to IBGM
There may be two ways to do it. I don’t recall if your core support has the removable brace in the middle like the older trucks. If it does have the removable brace, you can remove the grille and get the condenser out from the front of the truck. If not, you will have to remove the radiator and get the condenser out through the engine bay. I believe your truck does have the brace though.
1957 Cameo Carrier
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
06-11-20 05:21 PM - Post#2796176
    In response to wagonman100
I am pretty certain the radiator has to be at least tipped back toward the engine to get it out.
Remove the shrouds, then remove or reposition the radiator, remove condensor.
I stress if you are replacing the condensor to inspect the lines going to it. This era was notorious for leaking at the crimps on the lines. Now would be the time to change them
Old School GM fan FOREVER
IBGM
IBGM
Reg: 12-03-03
06-12-20 04:22 AM - Post#2796198
    In response to rockfangd
Figured it our last night. Super easy, remove front grill, remove 4 bottom bolts on latch support, remove 2 bolts on top of latch support and everything moves out of the way. Really well designed for a change!! So glad I didn't have to remove radiator. Thanks guys!
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
06-12-20 07:19 AM - Post#2796214
    In response to IBGM
Cool
Execution time: 0.128 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:15 PM
