Danchuk
Username Post: TH350 transmission problem        (Topic#361258)
HDALEF
HDALEF
Loc: Fort Worth, Texas
Reg: 07-02-03
06-03-20 05:03 PM - Post#2795596
Has anyone ever heard of a problem involving too much clearance between the converter and flex plate requiring shims or spacers to keep the converter engaged with the transmission pump?
Dale
'57 sport coupe "finished"
'57 sport coupe under construction
06-03-20 05:35 PM - Post#2795598
    In response to HDALEF
Yes, if you have a starter adapter plate.
HDALEF
HDALEF
Reg: 07-02-03
06-03-20 06:01 PM - Post#2795600
    In response to acardon
No, it
Dale
Site Ambassador
06-05-20 02:07 PM - Post#2795723
How large of a gap is it? We may need a little more info. like do you have a one or two piece rear main seal block, is this a new setup with a new flexplate, new converter, etc.?
1957 Cameo Carrier
Member #409
06-05-20 06:51 PM - Post#2795738
    In response to wagonman100
With the converter to flex plates bolts not installed, there should be 1/8"-3/16" clearance between the converter and flex plate with the converter pushed back as far as it will go.
Execution time: 0.209 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:02 PM
