Username Post: Moving away from Optima...what you suggest?        (Topic#361254)
56_Kruiser
56_Kruiser
Loc: St. Augustine, Fl
Reg: 09-23-05
06-03-20 03:39 PM - Post#2795575
I find Optima batteries (using Yellow Top) to be problematic. I've used them in my 56 and my 61. Naturally with those, they may be in garage w/o start for maybe weeks. If I don't put a trickle charge on them they go dead for sure.
The thing in particular that is a pain is that once they get low on voltage (lets say as low as 5v), then a normal charge will not take. You charge it in serial connection to another battery. That is, connect the low Optima to another battery with jumpers, and then charge the battery with voltage.
I'm wanting to move away from that.
Thoughts on batteries I should consider?
1956 Chevy
Vid of 61
61 Chevy
06-03-20 04:35 PM - Post#2795586
    In response to 56_Kruiser
I switched from Optima to Bosch 2 years ago, for the same reason. The Bosch just failed last week after only 2 years. I'm trying a Champion AGM this time.
56_Kruiser
56_Kruiser
Reg: 09-23-05
06-03-20 05:55 PM - Post#2795595
    In response to acardon
I had an acquaintance tell me that Odyssey were good.
1956 Chevy
Vid of 61
61 Chevy
Senior Moderator
06-04-20 05:16 AM - Post#2795632
I've had an Odyssey 78-790 AGM in my Silverado SS since December 2017, no problems so far. My starter crapped out around 100Kish miles, installed a new AC Delco starter, and the thing spins so fast it's amazing.
The only rough part is justifying the cost...about $245 shipped for mine at the time.
65_Impala
Reg: 12-29-02
06-04-20 09:43 AM - Post#2795646
Optima batteries really are nothing special. You can find lots of AGM batteries cheaper and with a better warranty.
Just get a cheap battery at Walmart or shop around and find the cheapest battery that still has a decent warranty. Stick an acid absorbing mat under it and go.
The Odyssey are good batteries but they certainly are pricey.
Don't let any car battery stay in a discharged state and definitely don't let it go dead. The maximum amount they should be discharged is well above the level of "dead". Abusing them like that is just reducing their capacity and shortening their life, despite what some manufacturers may claim.
06-04-20 11:38 AM - Post#2795660
    In response to 65_Impala
Most of us use AGM batteries because they are mounted in the trunk, which is open to the passenger compartment. The fumes from lead acid batteries are not only hard on upholstery, they aren't too good for humans either.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
06-04-20 12:50 PM - Post#2795663
I too, have moved on to the cheap Walmart (~$50) batteries for the cars I don't drive much. I leave them on a maintainer https://www.batteryminders.com/1510-12-volt-mainte... if the car is going to sit for more than a few days. Batteries don't care for being abused.
FWIW, lots of folks have been complaining about Optima batteries for the past 4 years https://www.thirdgen.org/forums/aftermarket-pr oduc...
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 06-04-20 12:51 PM. Reason for edit: No reason given.
56_Kruiser
56_Kruiser
Reg: 09-23-05
06-04-20 01:59 PM - Post#2795667
    In response to paulo57509
Where I got bit by the OPtima this time is I had it at a shop (still there) for some trans work. They are dragging their feet. They left the key fob which works by being in range in the car for several days and it ran the battery down. Then they tried to charge it with normal charge which doesn't work.
I brought it home last night and did the proper charging. Left with it at 12v this morning, but quickly it was at 11, then 10. So I suspect it is ruined.
I typically leave it on a trickle charger.
1956 Chevy
Vid of 61
61 Chevy
Senior Moderator
06-04-20 05:19 PM - Post#2795676
Have you considered switching to a battery that has provisions for a vent tube? I've never paid much attention to how common it is, but many modern cars are like this and have a tube that exits the trunk.
Anyway the setup is pretty simple; just a hose with a plastic elbow for the battery connection and a grommet for the hole in the trunk. The hose kits are less than $10. Not sure if all batteries have the provision for the connection, but I've noticed some have two holes and the unused one must be plugged.
65_Impala
Reg: 12-29-02
06-04-20 06:31 PM - Post#2795683
    In response to someotherguy
Or use a battery box that vents through the trunk floor.
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
06-05-20 05:47 AM - Post#2795702
MY PONTIAC G5 HAD A LEAD ACID BATTERY FACTORY MOUNTED IN THE TRUNK,IT USED A VENT SYSTEM FOR THE FUMES
https://sdparts.com/i-24085620-acdelco-gm -original...
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
06-05-20 08:08 AM - Post#2795710
Yes, I have thought about making a sealed box, vented overboard. If this Champion AGM fails before it's time, I'm going that route. I have a lead acid in my Corvair that is 11 years old and still cranks it after sitting for weeks.
IgnitionMan
Reg: 04-15-05
06-07-20 10:34 AM - Post#2795822
I gave up on Optima brand batteries a long time ago, they always failed very quickly after installation, or, just didn't work as well as anything else.
corvesy
corvesy
Reg: 08-07-08
06-09-20 08:42 AM - Post#2795982
    In response to IgnitionMan
I have had good service with Optima batteries. I have 2 that are over 10 years old. Whatever battery you use you need a maintenance charger or it will not last long if you are not using the vehicle often.
Senior Moderator
06-09-20 10:36 AM - Post#2795988
    In response to corvesy
I think that's just it - the newer ones are less durable. It seems that whenever Optima reliability comes up as a topic, ones that were purchased in the last few years don't last long for some people.
The last one I had I bought several years ago (can't recall, maybe 5 or so?) and it began leaking at the side post terminal, which was a bit surprising. Replaced the battery and the battery cable as it was ruined.
WagonCrazy
WagonCrazy
Reg: 06-07-05
06-15-20 07:20 AM - Post#2796397
I'm having good luck with Optimas. Most all batteries only good for 4 to 5 years with regular use.
But as with any battery, you either have to drive the car very regularly (to keep the charging up) or put it on a battery tender setup when parked for days on end.
Mine are on tenders, and the batteries go for well over 5 years.
Edited by WagonCrazy on 06-15-20 07:21 AM. Reason for edit: No reason given.
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
06-27-20 08:55 PM - Post#2797348
    In response to WagonCrazy
Lead-Acid. The old ways work best.
TAT_2
TAT_2
Reg: 10-29-00
07-01-20 03:06 PM - Post#2797666
    In response to Stinky
FOR YEARS I HAD LEAD ACID BATTERY'S RIGHT BEHIND ME IN MY C3'S
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Senior Moderator
07-08-20 12:48 PM - Post#2798225
    In response to TAT_2
For what it's worth, anybody considering an Odyssey battery might want to be sure you're buying from an "authorized dealer" - since many of us might go online shopping and look at a-zon, -bay, whatever.
I read some ugly reviews on a-zon about Odyssey and they were related to the warranty not being honored due to where the battery was purchased. Any manufacturer can have defects, but a-zon tends to be a questionable source for many items including bootlegs, seconds, returns, and what have you - I can't blame any brand for questioning the source as legitimate.
The reason I was shopping batteries in the first place is my 300 didn't want to start last night. A quick boost with my little jump box cranked it right up, though. Some checking and the battery date code is 2/13, so I can't really be mad at it. While cruising online prices for Odyssey, currently the best price I found is from Autozone! Around $25 or more cheaper than other places, which every dollar counts when you're laying out the bucks for one of these suckers.
Execution time: 0.124 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:30 AM
