Username Post: 4L60E noise        (Topic#361233)
opus
opus
Reg: 10-20-04
06-02-20 07:54 AM - Post#2795461
I had an alternator fry a while back. The grommet with the main power wire melted causing it to ground out. A subsequent noise developed in the transmission.
Not the easiest to figure out on video but it seems to be an electronic type noise. You cant feel it on the shifter or transmission.
Any ideas? https://youtu.be/LjEGqnhTp4c
Senior Moderator
06-02-20 09:51 AM - Post#2795467
    In response to opus
Definitely hard to tell long distance, but it seems a little bit similar to a noise my '94 2500 made after the transmission blew up and got swapped with a rebuilt unit. If I recall, the fuel hard lines were buzzing against the transmission case. That one can be hard to spot; I spent a lot of time under the truck with a bright light trying to isolate it.
Hopefully that's all it is. Odd noises are generally a bad sign with any transmission, but particularly with 700R4/4L60/4L60E's...
opus
opus
Reg: 10-20-04
06-02-20 01:43 PM - Post#2795487
    In response to someotherguy
Its been a year plus, nothing grenaded yet. Everything works, no codes flashing either.
Execution time: 0.077 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:01 AM
