Username Post: electrical problem        (Topic#361213)
larrybrowningmauldin
Loc: New Braunfels,TX
Reg: 08-16-05
05-31-20 05:53 PM - Post#2795345
I come to this forum because it gives the BEST help(mechanical, electrical, and sometimes spiritual) for my 1958 Corvette. The problem that I've had for years but haven't taken the time to solve...the right turn signal, front and back do not turn ON.
Driver side (left)
-brake OK
-parking front & rear OK
-left turn OK
Passenger (right) Violet wire
-brake OK
-parking, front and rear OK
right turn problem
a. no front turn signal
b. no rear turn signal
c. no brake light
d. When the brake lights are ON,with right turn lever up for right turn,right brake light turns OFF. When the turn lever is returned to center position, the brake light turns ON again.
Could this be the blasted/blessed switch?
Thanks for considering problem, Larry
06-01-20 05:59 AM - Post#2795372
    In response to larrybrowningmauldin
Yes, that's most likely the turn signal switch.
Reg: 08-16-05
06-01-20 06:07 PM - Post#2795428
    In response to acardon
Thank you for the answer. When posting, I told my wife that either ACARDON or DZAUTO would have the answer.
Reg: 08-16-05
06-08-20 11:31 AM - Post#2795889
Good news. It wasn't the sliding switch. I skipped a step in the previous troubleshooting. The passenger side front "parking " light worked, but I didn't check the bulb itself. The "turn" filament was fried with black residue inside the glass. I should have checked that component FIRST. Aged rookie! Thanks again.
Execution time: 0.105 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:21 PM
