Username Post: Another T-5 ?        (Topic#361209)
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
05-31-20 10:25 AM - Post#2795310
Got the tranny in am now working on the crossmember, I remember someone having the driveline hitting under the car, anyone who did this swap know how low the front driveline yolk should be from the floor pan ? or any other measurement that might help me with this. Thanks
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
06-01-20 05:44 PM - Post#2795426
    In response to 2D51STYDLX
Tuck it up as far as you easily can while keeping in mind, your pinion shaft in the rear end and your output shaft in your transmission need to be as close to parallel as possible. The one other consideration is you want a few degree angle at each ujoint so the needle bearings in the ujoints move. If the two shafts are pointing directly at each other, the needles won't move and will wear grooves in the joints.
You are going to love the T-5.
Just Slightly Abrasive
2D51STYDLX
2D51STYDLX
Reg: 03-03-11
06-01-20 08:50 PM - Post#2795442
    In response to 40grit
Thanks John, I was thinking of jacking up the tranny until It looks like there is very little weight or sag to the motor mounts on the bell housing, thought that might get me in the ball park ?.
Roger
John Prine
lobucrod
lobucrod
Loc: Slaton, TX
Reg: 10-01-07
06-02-20 01:01 PM - Post#2795484
You can measure the pinion angle and try to match that with the trans. Normally around 3 or 4 degrees down on the tranny end.
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
Execution time: 0.081 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:07 AM
