Username Post: 700r4 weird problem        (Topic#361201)
NinjaBarney7
Reg: 07-13-19
05-30-20 10:13 AM - Post#2795259
so I just put back in my700r4 in my 85 and swapped to new/used converter on recommendation of guy that did the patch job on thee tranny. worked fine for a few days less than 10 miles to be honest. now the car only moves for the first maybe 5 minutes. then refuses to send any power to the wheels and just revs. I can turn the car off for ten minutes and itll move for another half a mile. recon it could be the converter overheating?
05-30-20 05:33 PM - Post#2795276
    In response to NinjaBarney7
How does it act in reverse when this happens.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
06-02-20 09:04 PM - Post#2795518
What was the issue with the transmission that required the "patch" job?
Edit: Was/Is the TV cable properly adjusted?
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 06-02-20 09:09 PM. Reason for edit: No reason given.
NinjaBarney7
Reg: 07-13-19
06-07-20 10:26 AM - Post#2795818
same thing in reverse gear
NinjaBarney7
Reg: 07-13-19
06-07-20 10:30 AM - Post#2795820
    In response to paulo57509
When I bought the car the seller told me it needed to be rebuilt most likely due to some grinding noises, so I took his word for it and took the tranny to a guy and told him just to do what it needs. he said he didnt find anything wrong but replaced 3-4 clutches just because its older and common problem.(turned out when I reinstalled it the "grinding" was an improperly shimmed starter contacting the flexplate while running... fixed that easily hahaha
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
06-07-20 06:32 PM - Post#2795847
When you installed the converter onto the input/stator shafts, did you make sure the slots in the converter "snout" engaged the tabs in the pump rotor?
Not engaging the tabs will sometimes fracture the pump rotor causing a low/no fluid pressure condition - which sounds like your problem.
You can check the line pressure. Most parts places will have pressure test gauges for rent. Make sure the gauge has sufficient range. At this point, you're not so much interested in what the pressure is, just that there's pressure.
1987 IROC-Z 5.0L
2003 GMC Safari
Edited by paulo57509 on 06-07-20 06:33 PM. Reason for edit: No reason given.
Execution time: 0.194 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:23 PM
