Username Post: 46 large truck vs 1/2 ton cab differences & fender modification        (Topic#361179)
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
05-29-20 03:32 PM - Post#2795201
hi everyone
i was wondering if the fenders on a 3600 or 6400 are wider than the 3100. obviously the wheel opening is different but i hope to rework large fenders into 1/2 ton fenders. don't care if they're identical they just need to look right/good with 1/2 ton size wheels
if they ARE wider, so are the running boards?
thanks
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
05-30-20 08:52 AM - Post#2795250
    In response to drew1987
I don
1957 Cameo Carrier
05-30-20 10:35 AM - Post#2795261
Don't know if this will show what you want.
https://www.gmheritagecenter.com/docs/gm-heritage-...
29-41, 42-48, 49-54 Moderator
drew1987
drew1987
Reg: 02-23-14
05-30-20 06:24 PM - Post#2795278
Thanks all
It
Member:
05-30-20 08:24 PM - Post#2795284
I
1957 Cameo Carrier
drew1987
drew1987
Reg: 02-23-14
05-31-20 04:39 AM - Post#2795297
    In response to wagonman100
My thought was, as a car is sectioned to remove, say, 3
Member:
05-31-20 01:43 PM - Post#2795329
Remember the front of the large truck front fenders are shaped a bit differently than the 1/2 ton front fenders as well as over the wheels.
1957 Cameo Carrier
drew1987
drew1987
Reg: 02-23-14
05-31-20 07:34 PM - Post#2795349
Yes, for sure. But, what I wonder is, can a determined person make good looking at fenders out of the large truck models? It is likely I am going to use a three-quarter ton modern chassis And the tallest, skinniest tires I can find
Member:
06-02-20 02:39 PM - Post#2795494
Like I said, I have seen the big truck fenders used on street rod type trucks and they looked fine. The tall skinny tires help a great deal. To be honest, I was considering buying a truck with the large truck fenders on it and I didn
1957 Cameo Carrier
drew1987
drew1987
Reg: 02-23-14
06-03-20 04:58 AM - Post#2795541
Yea i guess i'll try it. I found 235/80/r17. Guessing thats as tall and skinny as I'll get without going to an actual truck tire. Not sure if this thing will be 1500/2500 chassis or trailblazer. Not sure if it will be (with either) a front clip on a straight frame I make from 3x6 or whatever is similar to the front clip, or if I'll use the whole frame and and make cab mounts that are tall to make up the difference. First stu is obviously the body work =)
Member:
drew1987
drew1987
Reg: 02-23-14
06-03-20 05:09 AM - Post#2795543
215/85/16 looks readily available and is 30.4" tall
Member:
Keroppi
Loc: NorCal
Reg: 10-24-18
06-22-20 08:18 PM - Post#2796960
I did some research on this in the past and what I was able to learn is that the cab is the same, but the fenders are different. I can't remember if the hood is different or not, but suspect it is the same. You can use a large truck cab and pair it with 3100 fenders.
Wayne over at Code504 has a fairly extensive knowledge about the Art Deco era trucks.
Alan
"Keroppi" - 1946 Chevy 1/2 Ton Pickup
Edited by Keroppi on 06-22-20 08:19 PM. Reason for edit: No reason given.
drew1987
drew1987
Reg: 02-23-14
06-28-20 08:28 AM - Post#2797366
    In response to Keroppi
Thank you! I
Member:
06-28-20 02:12 PM - Post#2797394
This shows how the larger truck fenders are formed in the front of a 46.
https://www.facebook.com/marketplace/item/2718 5105...
drew1987
drew1987
Reg: 02-23-14
06-28-20 05:01 PM - Post#2797405
Looking at it, you would swear that the runningboards are wider, the hood is longer
Member:
Execution time: 0.072 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:34 AM
