Username Post: Fan blades fully within shroud        (Topic#361162)
LSS1333
Reg: 05-13-15
05-28-20 05:00 PM - Post#2795100
Will a fan shroud help at all if the blades are fully within it? I know people recommend the fan blades be half in and half out, but that is not what I have.
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
05-28-20 05:08 PM - Post#2795101
    In response to LSS1333
I guess it all depends of the application
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
1965C-10
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
05-29-20 04:12 AM - Post#2795145
I don't think so, blade needs to be right in middle of shroud.
Imagine your house it hot, it's nice and cool outside.
You open window and put a box fan inside window frame, drawing in nice cool outside air.
Think about if the box fan was outside the window sitting on a chair, it would get air in, but some of the air would hit the house.
Also if the fan was inside the house on a chair, it would pull some outside air in, but it would also be pulling in air that's already in the house.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
05-29-20 06:42 AM - Post#2795158
It will 'help' (better than no shroud). But it is more efficient installed properly.
Pete
LSS1333
Reg: 05-13-15
05-29-20 08:12 AM - Post#2795168
    In response to japete92
Good replies. I bought a 6 blade metal fan, but don't have the shroud installed because the blades would be fully inside of it. I guess if it would help (more than not having a shroud at all) I will install it. I just didn't know if using the shroud with the blades inside would make things worse.
TAT_2
Member #26 "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
05-29-20 03:34 PM - Post#2795202
f you
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
All times are (GMT -0800) Pacific. Current time is 06:57 AM
