Username Post: convertible top        (Topic#361156)
first_63
Reg: 06-22-09
05-28-20 11:13 AM - Post#2795069
recently purchased a 1962 convertible and i have two questions. First who do you guys recommend i get a replacement top from with plastic window?Second the top on the passenger side bows down right at the joint by the window, will a new bolt and nut kit for the top fix this issue? thanks for any help.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
05-28-20 02:32 PM - Post#2795084
    In response to first_63
front top bows can rust through on top of the bow under the convertible top... check that first. A new top rack bolt kit costs $150 and includes the entire top rack to replace all the bolts and other parts.
There are only 3 -5/16 bolts per side with fixed washers that hold the side rails on the top rack to the front bow. You can see these 6 bolts by looking at the rack inside the car on both sides by the front bow.
There is a USA company that sells very good tops. Do not buy a overseas top...
They sell plastic and glass back windows.
The plastic back window will wrinkle over time.
When putting a top down the plastic and glass window should be unzipped everytime the top is put down.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
junky
Loc: Northeast CT
Reg: 06-27-10
05-28-20 03:56 PM - Post#2795095
    In response to pvs409
To add to what Paul wrote about the rear window, keep it clean and put a bath towel in the well when you put it down, and a bath towel on top of it before you put the top down. Get a copy of the top manual for directions how to lower your top. It will give you instructions for lowering the top, so you can get the top boot on without damaging it.
pvs409
pvs409
Reg: 01-10-05
05-28-20 08:31 PM - Post#2795128
    In response to junky
Buy the top from Topsonline who sells EZ on brand tops that are USA made tops.
They have a extensive list of installers for the top all around the country.
I bought a bright white top for my 62 SS white red interior convert plus my friend bought the same bright white top for his red/red 62 Impala SS
Convertible and a blue top for my 62 SS Nassau Blue blue interior convertible.
The fit is great, I have pictures of all three 62
first_63
Reg: 06-22-09
05-28-20 09:03 PM - Post#2795130
Thanks for the advice.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
05-29-20 06:33 AM - Post#2795157
LOTS of folding top info in the '61 Shop Manual (the 'base' manual for the Supplements).
Pete
Execution time: 0.122 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:46 PM
