Username Post: Fuse blowing AC        (Topic#361130)
jerryjerry05
Reg: 05-26-20
05-26-20 11:30 AM - Post#2794891
1999 Chevy Astro Cargo Van
The fuse under the hood blows the second I put it in.
The comp, new. the fan, new. the blower motor relay, new(changed it because the low speeds didn't work).
I unhook the comp and the fan and the it still blows the fuse as soon as I turn the key.
Still working on the system.Any idea's??
05-26-20 02:29 PM - Post#2794904
    In response to jerryjerry05
You have a direct short to ground on a wire that has power to it with the key on, or it is a switched circuit and the switch is on, You probably pinched a wire changing a component.
1957 Cameo Carrier
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-26-20 05:59 PM - Post#2794925
    In response to wagonman100
Check to see if the wire to the compressor is pinched behind the compressor.
HAve seen this before and it is a instant short.
(The harness side) I say this because you state it even blows with it unplugged.
Is it a 15A in the underhood box?
Old School GM fan FOREVER
jerryjerry05
Reg: 05-26-20
05-27-20 01:52 AM - Post#2794944
    In response to rockfangd
Now that I think about it? The problem was there before I changed anything.
The fuse under the hood is a 20a that keeps blowing.
In the other fuse panel by the brake it's a 10a.
It doesn't blow.
I'm digging deeper today, the switch on the dash will be checked today.
THANKS!!!!
jerryjerry05
Reg: 05-26-20
05-27-20 02:38 PM - Post#2795001
Todays results.
Found when the AC switch is turned on it blows the fuse.
I have the comp unplugged, the fan unplugged,motor running, and the fuse blows when I hit the switch for the fan(remember the fans unhooked) it then blows the fuse.
So I'm guessing the switch for the fan is bad?
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-27-20 03:24 PM - Post#2795005
Did you check the harness that goes to the compressor? (harness side, not compressor side)
Make sure AC switch is turned off, set controls to dash vents or bi level.
Turn on blower speed and see if it blows.
Does the blower motor work?
If the fuse does not blow turn on the AC.
Does the fuse blow??
AC circuit and blower circuit should not be related.
Edited by rockfangd on 05-27-20 03:25 PM. Reason for edit: No reason given.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
05-27-20 05:38 PM - Post#2795012
I had a 05 Silverado 4.3 with a similar problem last year in the shop. I followed the harness from the compressor to the main harness was chaffed and shorted out. I had to peel the plastic guard and tape back to find the short. Worth a look.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-27-20 08:41 PM - Post#2795031
    In response to junkman104
agreed. That is what I mentioned. I have come across it more than once. Especially if the compressor or something around it has been replaced
jerryjerry05
Reg: 05-26-20
05-28-20 02:24 AM - Post#2795044
I had changed the fan 6mo. ago. Works good.
The blower motor relay worked but only on the 3 and 4 settings. Changed that and the blower and switch work fine.
So I'm guessing the switch for the fan is bad? Or it's grounded somewhere in the harness??
THANKS!!
Gonna look at it this AM , got rained out yesterday.
Execution time: 0.143 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:29 AM
