Username Post: Harbor Freight jack stands recalled        (Topic#361120)
Jalapeno
Member #252
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
05-25-20 08:41 PM - Post#2794844
Harbor Freight has recalled jack stands that can suddenly collapse:
https://www.thedrive.com/news/33572/harbor-fre ight...
Jalapeno
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-27-20 04:39 AM - Post#2794949
    In response to Jalapeno
if you read carefully the jacks can malfunction if the user does not carefully verify the pawl on the jacks not correctly located the jacks are not breaking and failing its just posiable to set the jack stand up so the pawl is not fully inserted in the upright stand supports gear teath, so that it may not support the load safely
Edited by grumpyvette on 05-27-20 05:48 AM. Reason for edit: No reason given.
Execution time: 0.104 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:17 AM
