Username Post: Fuel filter        (Topic#361114)
RXN
RXN
Loc: Edmonton area, Alberta
Reg: 11-11-10
05-25-20 11:01 AM - Post#2794764
Truck is a 2007 6.0lt 3500 GMC HD (the new body style of 07)
Looking in the owners manual there is nothing on the fuel filter.
Looking under the truck. (As far as I can see with jacking the truck up) i dont see any filter on the frame.
Anyone know if they had filters in side of the tanks?
Reason I'm asking. Is I've been chasing a check engine light since 2016. Constantly replacing the purge valve. Then the dealership looked a little further and replaced the canister and sensor. And the light came back on. Code P0442.
This last week. They pulled the tank. Found the fuel pump was not sitting proper. Someone tightened it down with the notches misaligned. Resulting in a cracked housing. (Took 4 years to find that, actually took this dealership 4months, as i gave up on the other two shops o was taking it to).
I have a record book of everything ever done to that truck. But no mention of the pump ever being pulled
Closest I have is back in 2012 another dealership changed the fuel filter.
METAL'S REPAIRABLE
PLASTIC'S REPLACEABLE
PAIN HEALS
05-25-20 11:37 AM - Post#2794768
    In response to RXN
RockAuto doesn’t list a filter as being available. It probably just has the strainer on the pump assembly. A lot of vehicles are like that starting in the late 90s.
1957 Cameo Carrier
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
05-25-20 03:26 PM - Post#2794807
    In response to wagonman100
Starting in 2007, GM stopped putting a replaceable fuel filter in gasoline powered trucks. My 2009 Buick Lucerne does not have one either.
RXN
RXN
Reg: 11-11-10
05-25-20 03:44 PM - Post#2794814
    In response to dgstarr
Good to know thanks.
In 2012 I got charged by a GM dealership for one.
METAL'S REPAIRABLE
PAIN HEALS
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
05-26-20 02:17 PM - Post#2794902
    In response to RXN
The next time you go to the dealership take your receipt and ask them to show you the fuel filter.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-26-20 05:57 PM - Post#2794924
    In response to RXN
MAybe they changed the invisible one...
I am sure there is something logical lol.
No idea why they did away with fuel filters.
No filters after 05?? Somewhere around there. Likely cost saving measures
Old School GM fan FOREVER
elcamino
elcamino
Reg: 03-30-00
05-27-20 06:11 AM - Post#2794962
    In response to RXN
The fuel filter is INSIDE the fuel module which is inside the fuel tank. That started in 2004 (gas models). You have to change the complete fuel module. The good news is this filter design lasts longer because it only filters the fuel you burn in the engine. The older style frame mounted filters were always filtering fuel that circulated between the tank and the engine.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
Execution time: 0.123 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:52 PM
