Username Post: 57 Chevy 210 shuts off        (Topic#361113)
Yankiebar
Reg: 07-15-19
05-25-20 10:06 AM - Post#2794754
Had a generator light coming on, so decided to repace it with a new chrome one . Now the light is gone, the battery charges, but the car looses all electricity and it could be after 30 minutes of 45 minutes, it has a mind of it own. I did add an extra ground wire, so that is not the problem, I replaced the new generator, so that is not the problem. Wires are all tight and look good. Is there anything in the steering column that could make this happen ? 307 motor
05-25-20 10:46 AM - Post#2794760
    In response to Yankiebar
Is it a generator or alternator? If alternator, is it 1 wire or 3 wire?
Does it crank up after it dies? Does the horn work after it dies?
Steering column wiring is not involved, unless you have a aftermarket column with key on column.
Edited by acardon on 05-25-20 10:48 AM. Reason for edit: No reason given.
Yankiebar
Reg: 07-15-19
05-25-20 11:02 AM - Post#2794765
    In response to acardon
Nothing electrical works when it shuts down, so I move it to neutral and usually that is enough that the engine restarts itself. But not always .Its an alternator 110a. And its stock steering and ignition switch.
05-25-20 11:11 AM - Post#2794766
3 Speed? Restarts itself in neutral?
Sounds like a loose connection on the black wire between the starter battery terminal and the ignition switch. Check the plug on the back of the switcy for melted plastic.
Yankiebar
Reg: 07-15-19
05-25-20 11:17 AM - Post#2794767
ok thanks, will do this weekend.
Rucco49
Reg: 07-26-19
06-10-20 03:16 PM - Post#2796097
You got a ghost in there. How's the checking of the wires?
Execution time: 0.112 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:08 PM
