Username Post: Roller front wheel bearings        (Topic#361078)
Member #51
05-22-20 08:56 PM - Post#2794519
For those who wish to convert their front ball wheel bearings to tapered roller bearings, the source I have used for MANY years is Allied Bearing in Los Angeles. https://www.yellowpages.com/listings/9492737/dire c...
They ONLY fit 49-54 pass cars and 53-62 Corvettes. Some of the aftermarket Chevy and Corvette vendors sell them, but at a higher price than Allied (Allied MAY be the importer). These roller bearings for early Chevys and Vettes are NOT available through retular auto parts sources/stores such as NAPA, O'Reilly, etc.
Here is what the inner and outer roller bearings look like.
Attachment: Inner_roller_bearing.JPG (1.07 MB) 343 View(s)
Attachment: Outer_roller_bearing.JPG (1.07 MB) 357 View(s)
Mel Foye
Mel Foye
Reg: 09-29-00
06-15-20 08:49 PM - Post#2796466
Good job Tom. Any idea how to get a sticky here and in the C1 area? Mel
It Was On Fire When I Laid Down.
sidworks
Loc: Saturna Island, B.C.
Reg: 12-03-05
01-13-21 09:32 PM - Post#2812034
you did show the numbers on the cups for both. what are the nbrs. on the bearings themselves.
ron
dtreat
Loc: Virginia
Reg: 10-25-20
02-26-21 06:24 AM - Post#2815112
Assuming they fit right into the stock hub? How hard to get them in without any special tooks?
gcrkfrd
"7th Year" Platinum Supporting Member
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
02-27-21 08:35 AM - Post#2815194
    In response to dtreat
The races come with the bearings, and they almost drop in, snug them up, and back the nut off to the next hole for the cotter pin, spin the wheel to see if it spins. That spin is why drums on the front are better than discs.
1952 Styleline Sedan-
Blue 1967 C-20, Survivor.
The only running vehicles I own.
Airlifter
Airlifter
Reg: 06-07-15
03-02-21 06:05 AM - Post#2815394
    In response to gcrkfrd
Do you have a torque setting or do you just run them up until the wheel is hard to turn and back them off until the hole lines up?
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
1965 Corvair Corsa 140 hp 4 speed convertible
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
03-02-21 06:24 AM - Post#2815396
    In response to Airlifter
Never torqued front wheel bearings in my life, but that is my own way.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
04-26-21 11:16 AM - Post#2818824
If the spindle nut is snug enough to restrict the wheel from spinning, it's too tight. I run the nut up slightly snug, and then drop back to the previous notch. But if it doesn't spin freely back off one more notch.
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
Old-Soul
Reg: 04-29-23
08-04-23 11:35 AM - Post#2861109
    In response to 1971BB427
When installing these is a guy able to run the factory wheel seal or does the conversion require a different seal?
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
08-07-23 06:42 PM - Post#2861211
    In response to Old-Soul
Same Seal
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
08-12-23 05:59 PM - Post#2861433
Didn't they convert from roller bearings to tapered bearings due to the additional loads that the tapered bearings could handle?
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
08-13-23 06:11 PM - Post#2861493
    In response to Tony1963
I believe recommended procedure is spinning the drum/disc counterclockwise as you snug the nut then back off to nearest hole for the pin and check for free spinning and no play
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
meoirosiosi
Reg: 11-12-17
03-17-24 08:54 AM - Post#2868032
Bearing MFG is my go-to for converting front ball wheel bearings to tapered roller bearings. They've been reliable for years, offering parts not found in regular auto stores. Worth checking out for 49-54 passenger cars and 53-62 Corvettes
Execution time: 0.539 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:04 PM
