Username Post: Help stripping paint        (Topic#361074)
longboard
longboard
Loc: Grass Valley, CA
Reg: 09-20-04
05-22-20 10:19 AM - Post#2794481
Howdy, I am trying to remove all the paint from my intake manifold. I've tried all the products in the picture, nothing worked. What I have left is a gooie mess which I can't paint. Aircraft paint remover is no longer available due to the EPA. Help Please! Thanks!
Attachment: manifold.1.jpg (64.71 KB) 8 View(s)
Attachment: manifold.2.jpg (64.01 KB) 9 View(s)
Latest video Blue Persuasion ]
66cayne
66cayne
Reg: 08-06-08
05-23-20 08:15 AM - Post#2794547
    In response to longboard
is that a plastic manifold?
longboard
longboard
Reg: 09-20-04
05-23-20 09:14 AM - Post#2794548
    In response to 66cayne
Yes sir, some type of composite material. Pretty hefty. Any thoughts?
66cayne
66cayne
Reg: 08-06-08
05-23-20 11:30 AM - Post#2794555
the best way is a light media cabinet blasting. Here is a video that may help. power washer after you apply this stuff really helps. may need a small brush for the nooks and crannies
https://www.youtube.com/watch?v=oGmqkuMvxJc
longboard
longboard
Reg: 09-20-04
05-23-20 11:47 AM - Post#2794558
It contains methylene chloride which was banned by the EPA in 2018 except for industrial uses. It's what was in aircraft paint stripper. I used it a lot, it really worked great, but you can only get a few cans via eBay.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-24-20 06:12 AM - Post#2794614
Try some brake fluid. I know it will work on some paint.
05-24-20 07:38 AM - Post#2794625
    In response to aghaga
You may be able to get some aircraft stripper from a body shop supply house. If they won
1957 Cameo Carrier
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
05-24-20 08:16 AM - Post#2794634
I use Zip-Strip.
http://www.recochem.com/us/products/solvents_ clean...
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
05-29-20 04:29 PM - Post#2795211
Some people use Easy-Off oven cleaner to remove epoxy finishes from gun stocks. It might work in this case.
Back in the day, I used to soak stuff in a 5-gallon bucket of dirty carb cleaner. Stripped paint right off.
I too would be a bit concerned with the composite material being attacked by the chemical paint removers.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
06-18-20 11:41 AM - Post#2796666
You can still purchase stripper with "DICHLOROMETHANE"
check out This Place
I recently purchased two 1 Gal canisters.
Here is another Product that still contains the GOOD STUFF. Can only be purchased at certain Jobbers.
BUT as others have mentioned, no idea how it would affect the composite plastic.
58 Delray in disaray
Execution time: 0.13 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:56 PM
