Username Post: Tapered bearings without discs        (Topic#361071)
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
05-22-20 05:59 AM - Post#2794460
Hey all,
I think this came up recently but I cannot remember were... can some one point me toward tapered wheel bearing for 54 bubs that are NOT discs?
Drew
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
05-22-20 07:00 AM - Post#2794464
    In response to drew1987
Search Tool PSA
Attachment: 2020-05-22_6-56-59.jpg (546.81 KB) 3 View(s)
Attachment: 2020-05-22_6-58-28.jpg (496.98 KB) 7 View(s)
Airlifter
Airlifter
Reg: 06-07-15
05-22-20 12:12 PM - Post#2794487
Ecklers early Chevy. I didn't see them in the catalog bt they are online
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
05-22-20 05:31 PM - Post#2794510
Search DZAuto (Tom Parson) he as answered this many times. I need to have him post it as a sticky, because I cannot pull it out of a topic.
29-41, 42-48, 49-54 Moderator
drew1987
drew1987
Reg: 02-23-14
05-23-20 05:16 AM - Post#2794527
actually, i've never been "good" at the search function, that was helpful in another way!
Found eckler's. Just out of curiosity, at 144 bones, they are worth the upgrade right? cause I have some bearings in storage... Likely will just throw in the tapereds under the assumption that they are safer and will last longer with frequent 65-70mph driving?
Also, does the installation still mean 33ftlbs and then back off to the nearest 1/6th where a cotter can go in? Or however its worded - i've of course done it more than a couple times having put many miles on my car, i just want to be sure the procedure isnt different. I just did a rear bearing seal on a 3/4 ton chevy (2002 MY) and it was: "tighten to XX foot pounds while turning the hub at the same rate as the wrench then back off X/X turn" the result was more or less finger-tight but the initial pressure had pressed everything into place
Member:
Edited by drew1987 on 05-23-20 05:25 AM. Reason for edit: No reason given.
05-23-20 12:36 PM - Post#2794561
DZAuto, Made a sticky on the roller bearings.
drew1987
drew1987
Reg: 02-23-14
05-24-20 06:42 AM - Post#2794617
These are ordered and should be here this week. I am going to go this, measure my hubs for runout, new shoes, and the 4 new tierods (once the elongated adjusting sleeve for the pass. side arrives) all at once. Thanks all
Member:
Execution time: 0.193 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:24 AM
