Username Post: 1964 impala speedometer        (Topic#361052)
basstracker
Reg: 11-09-18
05-20-20 07:12 PM - Post#2794328
my speedometer won't work so i took the cable off the speedometer and drove down the road. the cable didn't spin.i took it off the trans and the driven gear is good. so i need the drive gear on the rear of the trans.can someone tell me what color gear i need. it has a 350 turbo and 15 inch tires.p205 70r15.i would like to have a new gear when i tear it down. thanks
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
05-21-20 05:41 AM - Post#2794371
    In response to basstracker
Did you make sure the cable end was seated in the gear? Push the cable in hard when stopped while turning it and when the square end inside the tranny is seated, you should not be able to turn the cable.
Member #2194
Execution time: 0.125 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:28 AM
