Username Post: Running too warm        (Topic#361051)
rls8836
Loc: North La.
Reg: 01-30-02
05-20-20 04:26 PM - Post#2794311
My 55 has a 1974 350 engine, stock two barrel carburetor. Seldom drive it, but every time I do, the temp. Gauge will slowly come up and go to about 230, then suddenly go down to 180 then back up to 230 then back down to 180. Does this usually twice. After it stops that fluctuation it will stay right at 180 unless I
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
05-20-20 06:10 PM - Post#2794323
    In response to rls8836
Cheapest and easiest is a new thermostat.
57 Bel Air 2dr Ht
327 700r4
rls8836
Loc: North La.
Reg: 01-30-02
05-20-20 06:59 PM - Post#2794326
    In response to 57tim
57tim, that is correct. I
05-20-20 06:59 PM - Post#2794327
Fluctuations like that are usually caused by air in the coolant. Idle the engine with the cap off and the front end as high as you can jack it.
If it's getting hot at highway speed, it could be a clogged radiator. You should have plenty of air flow at highway speed.
rls8836
Loc: North La.
Reg: 01-30-02
05-20-20 07:14 PM - Post#2794329
    In response to acardon
You know I
rls8836
Loc: North La.
Reg: 01-30-02
05-20-20 07:20 PM - Post#2794330
I
Member #409
05-21-20 10:03 AM - Post#2794390
As acardon said, the temperature fluctuation when warming up like that is often an air bubble.
Increasing temperature with increasing speed is a separate problem that certainly could be a clogged radiator. Thing is, a thermostat that doesn't open fully can do that too.
So I would put a new thermostat in it as 57tim suggested.
rls8836
Loc: North La.
Reg: 01-30-02
05-21-20 06:53 PM - Post#2794426
    In response to Rick_L
Thanks for the reply
05-22-20 09:02 PM - Post#2794520
Try the thermostat first. Going up that high and then a severe temperature drop indicates it may be sticking. You can hook up a 6 cylinder radiator to a V8. I
1957 Cameo Carrier
05-23-20 09:19 PM - Post#2794596
i would put a new thermostat in it. preferably oem. when a cold engine gets up to stat opening temp the hot coolant will go into the radiator. the cold coolant will go into the engine and close the stat. this will go through a few cycles like this until the system gets up to operating temps.
toms57
Loc: Caney, Ks, USA
Reg: 10-28-01
05-24-20 12:24 PM - Post#2794652
    In response to bobb
If It was me, I would do the thermostat with a small hole in the flange first. If that doesn't work, I would replace the radiator, preferably with Aluminum. I wouldn't spend anything on a radiator that is that old.
Toms57
57tim
57tim
Reg: 11-09-01
05-24-20 06:46 PM - Post#2794699
    In response to toms57
Get a good quality one. I recommend Stant. Beware of cheap ones, they don't last very long.
57 Bel Air 2dr Ht
327 700r4
Rucco49
Reg: 07-26-19
06-09-20 10:19 PM - Post#2796046
Have you tried a new thermostat?
Execution time: 1.512 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:15 PM
