Username Post: Master Cylinder Fluid Evaporating        (Topic#361042)
buker55
Reg: 01-16-07
05-20-20 10:53 AM - Post#2794282
Every late fall I park my 55 Chevy in a heated and conditioned garage all fluids are topped off and fine. The car doesn't run until spring. When I open the hood to get it ready to start in the spring I have small yellowish crystals all over the master cylinder and the brake fluid is down to where the level is approximately half full. The crystals are not sticky and wipe off falling below the master cylinder which I blow off. Does anyone else have this problem or have any ideas as why this occurs?
55MAS
Loc: North Coast, USA
Reg: 12-19-01
05-20-20 01:36 PM - Post#2794295
    In response to buker55
read this link:
https://en.wikipedia.org/wiki/Brake_fluid
Member #409
05-20-20 04:16 PM - Post#2794308
Brake fluid isn't going to readily evaporate, particularly when the car is in storage - because the boiling point is so high. Also, any liquid is going to evaporate more readily at higher temperatures, which are only going to occur when the brakes are used.
Brake fluid does expand and contract with rising or lowering temperature. If you fill the reservoir to the top when it's cold, it's going to expand when the brakes are used and this may cause the reservoir to overflow. Another cause of a lower fluid level in the reservoir is a leak that you can't see. You might have a leak at the rear of the master cylinder, or more likely, a wheel cylinder.
Execution time: 0.111 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:48 PM
