Username Post: Remote transmission cooler        (Topic#361040)
Saddlemaker
Loc: Tucson, Arizona
Reg: 01-21-05
05-20-20 08:47 AM - Post#2794273
Have a 55 Chevy 2dr sedan with a crossflow radiator and air conditioning. The radiator does not have a trans cooler. I don't want to put the remote trans cooler in front of the radiator as I already have the evaporater there. Any suggestions for a good spot that will not block the radiator? Have a built 383 that needs lots of cooling.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-20-20 09:18 AM - Post#2794277
    In response to Saddlemaker
you might find this thread helpful, look it over carefully
on my c4 corvette I needed a larger transmission fluid cooler, space is veery limited, I mounted it under the gas tank inside the spare tire carry compartment
Edited by grumpyvette on 05-20-20 09:19 AM. Reason for edit: No reason given.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
05-20-20 01:36 PM - Post#2794297
Here is what I did for a transmission cooler for my '57 Chevy. It is mounted under the floor outside of the frame on the passenger side. The cooler has a thermostatic switch for the fan. B&M has a nice one that uses a Spal fan and has a built-in thermostatic switch. I added the piece of metal on the front side to help flow air into the cooler when the car is moving. No trouble after 10 years of use. Trans is a 700R4.
Attachment: cooler1.JPG (85.77 KB) 9 View(s)
chevyman
chevyman
Loc: Graham,Texas
Reg: 12-24-02
06-07-20 07:42 PM - Post#2795856
    In response to 5Larry7
My trans cooler setup is about the same as Larry`s. Been running it for over 10yrs now with no problems.
Terry
http://www.cardomain.com/ride/480775/1957-chev role...
vabeach56wagon
vabeach56wagon
Loc: Chesapeake,VA,
Reg: 04-22-02
06-17-20 10:06 AM - Post#2796578
This kind of cooler can run down the side of the frame. There's plenty of room in a '56 to put it as we did. Not true of the '55s.
paul
Original builder of the Gobstomper - '56 210 9 passenger wagon now in other's hands. Current Ride is '69 X33D80 Z28 Camaro
Execution time: 0.076 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:32 AM
